Effect of Polarized Sunglasses on Model S's Touchscreen & Dashboard
Discussion in 'Model S' started by smorgasbord, May 15, 2012.
Tags:
  1. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    Got to sit a Model S Beta model with my Maui Jims this morning. The good news is that the view through these polarized sunglasses was very nice - way better than looking at my iPhone 3GS, for instance.
    The video below shows how tilting your head affects how much light gets through. Interestingly, the Dashboard screen wasn't symmetric. 45 degrees to the right and the screen is completely dark. But, you can go past 90 to the left without affecting brightness much.
    [video=vimeo;42249096]https://vimeo.com/42249096[/video]
  2. doug
    doug Administrator / Head Moderator
    SF Bay Area
    Cool! Glad to finally see that test done. When level, your sunglasses are vertically polarized (to block horizontally polarized glare). Looks like the output of the 17" touch screen is also vertically polarized, which is great.
    Looks like the instrument cluster screen is a more standard LCD and has the typical 45 degree diagonal polarization. To get extinction by tilting to the left, you'd need to go past 90 to 135 degrees. Though, too bad they couldn't get a vertically polarized LCD for that as well.
  3. AndyM
    AndyM Member
    Sherwood, OR, USA
    Thank you for the test video! This is a good confirmation that TM has user experience in mind in the design.
  4. AnOutsider
    AnOutsider S532 # XS27
    So would this (the polarization of the screen) explain why those who have tested it out in the sun have experienced little glare? If so, perhaps the cluster LCDs aren't polarized in a similar manner because they're more shielded from the sun?
  5. doug
    SF Bay Area
    On its own, no. But it suggests that the screen manufacturer built it to customer (Tesla's) specifications. So perhaps they're also using some anti-glare scheme.
    Standard LCDs tend to be polarized at 45 degrees. I would guess this is because the application might be in either a landscape or portrait orientation. (Or switch between the two like your phone or tablet.) Polarizing at 45 degrees ensures that in case the user is wearing polarized sunglasses, he at least sees something. So I think the instrument cluster LCD is a more off the shelf item, which is perfectly fine.
  6. vfx
    vfx Well-Known Member
    CA CA
    Yeah, not too many instances that are comfortable where the driver is tilting their head that much.
    While wearing sunglasses.
    Zombie decapitation?
  7. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    I only tilt my head that much when I'm nodding off.
  8. doug
    SF Bay Area
    Well at least it lets you tilt your head in the right direction.
  9. gjamrok
    gjamrok Junior Member
    Culver City, CA
    Thank you! I was just about to post a question about this and searched to find you already did the work. :)
