Efficient Tire/Wheel Comobo for road trips
Should I do it?
  • You're nucking futs
    Votes: 2 12.5%
  • It's a great idea
    Votes: 7 43.8%
  • No Idea, but tell me how it goes
    Votes: 7 43.8%
  • Total voters
    16
chadever
57
89
Orem, Utah
I'm thinking about an ultra light weight/narrow combo for road trips.
T-Sportsline 19x8.5" wheels (25 lbs)
XTREME CONTACT 245/50 R19 105Y XL (27 lbs)
That puts the wheel & tire weight at 52 lbs, or 53 lbs if I stick 255 tires on the rear.
OEM tire/wheel weight combo:
62.6 lbs (20" slip stream)
73.5 lbs (22" + Goodyear)
75.5 lbs (22" + Pirelli)
According to Teslike, there's a 17% difference in range between the 22" and 20" wheels. They tested the 22" performance, which uses the Goodyear tires.
Teslike.com
22" GY tires are 1.8% wider than the 20" tires
22" GY wheel/tire combo is 17.4% heavier than the 20" combo
22" GY tires have a 16.1% wider tread than the 20" tires (GY vs Continental + Summer vs AS, may measure differently)
20" tires are 10.2% wider tire than the 19" tires
20" wheel/tire combo is 20.4% heavier than the 19" combo
20" tires have a 7.4% wider tread than the 19" (both Continental AS)
Obviously I can't account for aerodynamics, but the T-Sportsline turbine style wheels still seem like an aerodynamic choice.
What kind of range increase should I expect, if any? I believe the most important factors are tread width, tire width, wheel width and aerodynamics. Weight is important, but I believe rolling resistance and aerodynamics are more important.
Also, am I crazy for wanting 245mm tires?
P85_DA
4,171
2,872
Personally I roll on 22’s and do a lot of long distance driving ...with density of supercharging network I don’t ever seem to have problem with range ..by switching to 20s myself I don’t think I can necessarily skip pass a supercharger which would be the reason why I would do if that was possible ..I like the looks of my 22s range not so much :eek:
Reactions: Nautikelz
chadever
57
89
Orem, Utah
My LR+ with 22" can go about 236 miles at 80mph, and that's if I want to go from 100-0%
With OEM 20" wheels/tires I could get 277 miles (a 17.67% improvement)
5% improvement over 20" = 291 miles at 80mph
10% improvement over 20" = 305 miles at 80mph
15% improvement over 20" = 319 miles at 80mph
If it were to create a 15% improvement, I would be able to go 223 miles by charging to 80% and run down to 10%. Again, by comparison, my 22" need to use 100% of the charge to do 226 at 80mph.
Reactions: VikH
P85_DA
4,171
2,872
Thanks for info ..I have never been able to get more than 200miles on 22s I have never charged to 100% but based on my charging to 90% if I did do 100% not sure I would end up at 200miles with a charge nearby ;)..given weight of X I’m not sure personally if I would want to drop wheel size lower than the 20s .only game changer for me if I was able to skip a charger on a long distance drive ..:eek:
Qbenjamin
Frugal But Classy!
Jan 7, 2017
1,139
673
Braavos
I took a trip recently (600 miles total) and noticed that my efficiency with the 22's wasn't as horrendous as I previously endured. When I set the height to low, acceleration to chill and switch to range mode, I was actually surprised at the efficiency. In most areas, I was doing 75mph and I still averaged nearly 375 Wh/mi. In other areas, I hovered around 407 Wh/mi, which was much better than my 450 Wh/mi consumption on a previous trip.
Reactions: P85_DA
Mysta
Former Vendor
Feb 4, 2019
222
128
Greenville, SC
They're made for the X (suposedly) and the wheels load rating is 1,980 lbs.
Tesla Model X 19
Been thinking about getting these myself. Actually kinda back and forth in getting trip wheels for my PX and just swapping to S, but it almost seems like an even trade going to S and seems like too big of a loss so I keep coming back to the wheels.
chadever
57
89
Orem, Utah
I got the wheels today and I decided to go with Goodyears Eagle Exhilarate 255/50/19, but they wont be in until Monday. The Continentals diameter was a little too far away from the OEM's for my liking. The Goodyears add two pounds per wheel, but they have the same tread-width and provide a higher load capacity.
-54 lbs with the wheels, a 13.7% decrease from the 20" OEM's
-8.1" tread-width, a 7.42% decrease from the 20" OEM's
Reactions: VikH
nuP90D
31
9
Philadelphia
I do swap back and forth between the 19 and 22s. With the 22s on my P90D, I can't even get 160 miles. With the 19s, i get about 210 miles. Driving both around 70 mph on a highway.
My local Mavis Tires swap them for free if you ask them for a tire rotation service. I usually tip them $25.
I bought the 19 rims from tiretrack.
VikH
941
770
Midwest, USA
Teslike.com
Note the 22" GY tires are summer tires, so rolling resistance is likely very high. I put Continental DWS tires on my aftermarket 22" wheels and range reduction has not been terrible. Definitely less efficient, but not +15%.
Did you look at the Tesla MX 19" Cyclone wheel option?
I would expect very good range, but I wonder if braking, accelerating, and handling will be reduced.
The obvious issue is aesthetics. The Model X looks awkward with anything less than 22" wheels. 19s will look odd.
You have never charged to 100%? Why?
Saghost
8,216
7,000
Delaware
Do it. And record the results with as much detail as possible (weather conditions, average and max speeds, elevation change) over a bunch of miles so we can all learn from your experience. :)
The tire design and rubber compounds make significant differences in rolling resistance in addition to the geometry and weight aspects you’re analyzing, and the OEM 20s are an efficient all season tire, whereas the OEM 22s are sticky high performance tires.
I bought a set of Blizzak snow tires in 19” for my X last winter, and they added 10-15% to my consumption as best I can tell (weather changes make overall comparisons hard, but the trips right around the changeover gave me a decent impression.)
Reactions: VikH
VikH
941
770
Midwest, USA
never find need too..when I do long distance driving 100% doesn’t allow me to skip over SCs so I would rather get to SC at lower SoC to speed up charging
I always AC charge at home to 100% before I set out on a road trip. Why wouldn't you do that?
I understand not charging to 100% while you are on a road trip or during normal day-day driving.
Bigriver
378
314
Pittsburgh, PA
I charge to 100% sometimes, but I can give an example of why it doesn’t always make sense.
On a trip I make often, it takes about 60% of my battery to get to the first SC. I typically charge to 80% at home before I leave, arriving at 20%. If I started at 100% (which annoyingly takes away all regen at the beginning of my trip), I arrive at the SC at 40%. I need 70% as I leave that SC to get to the next SC. The time to get from 20% to 70% charge is only negligibly more than the time it takes from 40% to 70%. Actually, I just looked at my last trip data and it was 7 minutes to get from 20% to 40%. If I’m in a situation that that 7 min was important to me, if I have some uncertainty in the agenda or route and want more margin, I charge higher at home at the beginning of the trip. But otherwise I treat that first segment like all my trip segments: charge what I need to get to the next charger. Riding the bottom half of the battery increases the charging rate substantially.
Mr. Ed
58
57
Teslike.com
VikH
941
770
Midwest, USA
I don't understand - why you would want to charge less before starting off on a trip? Why would you want to spend the extra 7 minutes charging?
Bigriver
378
314
Pittsburgh, PA
Because I live at the top of a very big hill, and I don’t particularly like riding my brakes all the way down it when I don’t have regen if I’m fully charged. And I don’t think 7 minutes is much time. It’s actually probably less time than that because I didn’t account for the ramp up if starting at 40%.
But by all means, if that almost 7 min is valuable to you, start fully charged from home. Put it to good use somewhere else.
