I thought this copper-rotor thing is Tesla's (patented) trick and AC used aluminum rotors?AC Propulsion’s air-cooled copper-rotor induction motor produces maximum torque from zero to 5,000 rpm and spins all the way up to 13,000 rpm.
Maybe BMW will give ACP a hand in optimizing their manufacturing procces.We’ve studied the EV-1 motor carefully. The technique they used to construct their copper rotor was not great, resulting in suboptimal efficiency, and (I suspect) low manufacturing yield.
We have studied AC Propulsion’s rotor manufacturing technique. Their process creates a motor with much better efficiency. But there is quite a bit of hand labor and tweekmanship in the process, and it would not work for the production volumes we forecast at Tesla.
AC Propulsion batteries? I don't think so.Mounted where the back seats would normally be are 5,088 AC Propulsion lithium-ion battery cells, similar to those in most mobile phones.
That seems ridiculously long to wait to get moving, an EV should start at least as fast as an ICE.Starting takes about 10 seconds, as the electronics check the state of the battery and confirm the vehicle is working correctly.
Doesn't look particularly crash worthy. I wouldn't like to be sandwiched by those batteries.
