Since this thread title doesn't specify range at all I recommend you start a thread about long range electric planes only if you're so motivated. This thread is just fine as it is.
You are unfortunately not the first person to create a false narrative, I didn't describe the 737 at all, or even mention it ....hahaha, congratulations! You also seem to have no interest in contributing anything to this thread other than complaints.You might be the first person to ever describe a 737 as "long range".....hahaha, congratulations!
This is the boys toys thread. Real men go here:
VTOL Supersonic aircraft
no, you don't get to make up narratives then accuse others of false narratives.You are unfortunately not the first person to create a false narrative
The main problem with batteries is, landing weight is the same as take-off weight.
Which means EV planes should weigh close to the weight of an ICE plane with empty tanks. I am not even sure today we are anywhere close to that in terms of gravimetric density for even the highest energy density LiOn battery with Co & Ni.
What are you talking about? All the airplanes I have flown are designed to land with a full tank.
Or look up any regional turboprop specifications, maximum landing weight is generally very close to maximum takeoff weight. As in 95% full tank.
That is correct, as an Aerospace Engineer that has certified multiple platforms and systems that are directly applicable to this, we always end up certifying max landing weight very close to max TO weight except with special conditions. It's not as efficient really because the lighter an aircraft gets through it's flight plan the lower AOA needed to maintain lift and therefor the CoD reduced make for more efficient flying, but it can be accounted for just fine.
Here's a fact: I never mentioned the 737 or it's range, or any plane weight or range. You're having an argument in your own head divorced from reality.So you can have your opinion, but you can't have your own facts.
See the Pipistrel Taurus Electro. I have one. It's got a 40 kW motor (actual peak output is something like 33 kW), which is enough to climb at a decent clip up to soaring altitude. Battery runtime is something on the order of 20-25 minutes. It's got battery power for 8,000' of climb - enough for a few launches to 2,000' or a full day of flying if you're able to find some thermals.
Let's try with a recap of mine. My job for the past 25 years has specifically been the design of new airplanes, jets and turboprops. My answers may be sometimes a bit obtuse or overly complicated, and not always correct, but I will try my best to explain what the deal is.Here is a recap:
Great post.One could also modify an existing widebody to operate ultra-short-haul flights. A cool example is the Boeing 737-100SR designed for Japan Airlines. It had a ratio of maximum landing weight to maximum takeoff weight of 94%, a huge difference when compared to the 747-400 at 72%.
Thanks, yes a typo, I meant the 747-100SR.Great post.
One typo - I'm sure you mean the 747-100SR.
The fate of those Japanese models is instructive: high speed rail killed their economic niche, and increasingly high speed rail is driven via renewable electrics. Will this be the first generation of aero engineers to witness a shrinking market (absent post-war stuff).
This fixation on maximum landing weight being an issue for electric airplanes, which I frequently read on various forums, is a total mystery to me because it is a problem that does not exist, and worse, even if existed it would not be a problem either. So it's a double strike.
The problem does not exist because there are many very successful airplanes that have their maximum landing weight equal or extremely close to their maximum takeoff weight. That is the case of virtually all general aviation airplanes except the largest ones (all that I have flown as a private pilot), for example the incredibly successful Beechcraft Bonanza has a maximum landing weight equal to its maximum takeoff weight of 3805 lb. It is also the case of the majority of short range turboprops. One example I gave earlier in this thread is the ATR-42 which is more dominant in its market space than the 737 is in its market space. Its maximum landing weight is 40344 lb versus 41005 lb maximum takeoff weight, or a 98.3% ratio that I would qualify as extremely close. This is similar to other extremely successful airplanes like the De Havilland Twin Otter (98.4%) and simply represent the approximate fuel burn of taking off, flying the pattern and landing immediately.
So having a maximum landing weight at or very close to the maximum takeoff weight does not prevent an airplane from becoming extremely successful. It. Is. Not. A. Problem.
It is actually the way this is done for airplanes having technical similarity with electric airplanes: not very large and not going very far.
You provide an example for the 737-800, I can tell you that the large difference between its maximum landing weight and maximum takeoff weight is not the reason it is such a successful design. The ratio of the two is 83.9% which is about the same as the A321 at 83.2%. It is just the way it is done for that particular category of airplanes, as it allows the aircraft structure - including the landing gear - to be designed a little bit lighter, since these airplanes rarely fly less than an hour on a typical mission.
Electric airplanes must be significantly heavier than their ICE counterparts for a long list of reasons, and and the maximum landing weight "issue" is actually not on that list of reasons, because their ICE counterparts having similar characteristics (size and range) already have their maximum landing weight at or near their maximum takeoff weight.
Beechcraft built and sold over 17000 Bonanza, far more than Boeing sold 737s. And it is still in production.when you cite examples of niche, poorly selling, and discontinued aircraft (or ones that got beat by trains), it doesn't really help your point.
@EtnaLet's try with a recap of mine. My job for the past 25 years has specifically been the design of new airplanes, jets and turboprops. My answers may be sometimes a bit obtuse or overly complicated, and not always correct, but I will try my best to explain what the deal is.
