Electric/Power Boost another EV (Share energy)
Discussion in 'Model S: Battery & Charging' started by Macgaver, Feb 4, 2015.
  1. Macgaver
    Macgaver Member
    Montreal, Canada
    Idea for Tesla: Possibility to plug a Tesla power cable between two cars to boost another car. Same voltage/interface would probably make it easy/fast!
    Imagine quickly give some juice to another EV in problem ! Definitively would save some range anxiety
    What do you think ?
  2. Saghost
    Saghost Well-Known Member
    Delaware
    Without a bunch of hardware, that's a quick way to kill both batteries.
    If you connect a fully charged battery pack that's sitting at ~ 430V in parallel with a drained on that's only at 360V, the result will be a surge of current from one to the other limited only by the internal resistance of the two packs - which is as small as Tesla can make it for efficiency reasons.
    With no controls, this surge could burn out wiring and contactors, overheat cells, or even blow Tesla's individual cell fuses.
    The safe way to do it would be with a dc dc converter module - but it seems like an unlikely enough scenario that I'm not sure why anyone would invest in and carry a big expensive dedicated box for the purpose.
    I guess the one more or less safe way without additional hardware is through the road - hook the two cars together, and tow the drained car with the charged one while the drained car regenerates. You'd have to be careful not to put too much load on the tow bar, and you'll lose some energy on both ends, but as long add the mechanical bits hold together, nothing bad would happen.
    Walter
  3. arg
    arg Supporting Member
    Cambridge, UK
    These guys sell such a thing:
    http://www.andromedapower.com/ORCA_Inceptive.php
    (CHAdeMO to CHAdeMO rather than Tesla to Tesla, but the problem is the same).
    However, as a chunky box selling at about $25K, this is aimed more at the likes of AAA rather than for ordinary motorists to carry around on the off-chance.
  4. tga
    tga Supporting Member
    New Hampshire
    Someone in the Netherlands did this with a Leaf. Watch on YouTube to turn on English subtitles:
    The fastest way to charge your Nissan Leaf without power supply - YouTube
    A AAA card in your wallet is a lot more compact - "Hey Mr tow truck driver, can you give me a lift to the nearest Supercharger?" AAA plus gives you 100 miles free towing, which would get you safely to a SC in many cases.
