Electrical access from cabin to frunk
Discussion in 'Model S' started by jjchan, Sep 6, 2014.
Tags:
  1. jjchan
    jjchan Member
    Athens, Ohio
    I want to install a Blackvue dash cam behind the rearview mirror and run the wire from the A-pillar to the frunk, where I can connect it to the fuse-box. Can someone who has done it before help with some directions.
  2. mmh
    mmh Member
    SLC
    I installed a Blackvue myself recently. My car (June 2014 production) had the extra (unused) 12v always-on power connector in the area of the roof where the microphones are. To remove the panel, just push it towards the windshield and pull down.
    Images:
  3. jjchan
    jjchan Member
    Athens, Ohio
    @mmh: I'm having problem identifying the plug on the 3rd photo. I'm picking up my P85 next Wed 10. I'll definitely open that compartment to see if I have a unused plug. Please post some pic of that plug.
  4. jjchan
    jjchan Member
    Athens, Ohio
    Could you also describe how you make the connection in the compartment. Thanks
    - - - Updated - - -
    A clearer picture of the connector will really help.
  5. mmh
    mmh Member
    SLC
    Take two pins off this (Break Away Headers - Straight - PRT-00116 - SparkFun Electronics) and solder them to the ends of the blackvue power cable.
    Then plug black into black and plug red into blue-red.
    Doing it this way means you don't have to cut into the cars wiring and can remove the camera easily if ever needed.
  6. ABVA
    ABVA Member
    Northern Virginia
    In newer models that connection most likely is not available. However, to gain access to the fuse box in Frunk from cabin you want to review the "Lighted T installation instructions" at:
    Tesla Model S Lighted T Installation Instructions - TESLARATI.com
    specifically instructions for installing the diode in the cabin which mimics the behavior of Lighted T. It is almost towards the end of instructions, just before the video.
  7. mmh
    mmh Member
    SLC
    I've seen people saying that since before 2014 on these forums. Yet my car a June-2014 has the connector. I think that connector's existence might depend on another variable like the tech-package.
  8. ABVA
    ABVA Member
    Northern Virginia
    Mine is Nov. 2013 with Tech Package but no extra connection in the mike area. It is great that you have it, makes life a whole lot easier. I do have Dual Channel INAVI FXD900 with power sourced from the fuse box in Frunk.
  9. mmh
    mmh Member
    SLC
    Yeah, that's so odd. I wonder why some cars have it and not others. If you want to compare, my load-out is:
    P44490 S85, Panoramic, Tech, Folding Mirrors, Fog, Air Suspension, Performance Seats, Interior Lighting, Parking Sensors, Ultra High Fidelity Sound, Dual Chargers, Subzero Weather
    Looks like the only real difference between our cars is possibly the dual chargers and/or subzero weather.
  10. ABVA
    ABVA Member
    Northern Virginia
    Hello jjchan,
    please let us know if we were helpful? (Mmh & myself)
  11. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    They may have removed it from the standard build and added it back in recently. They're working on all kinds of driver assist stuff, supposedly, so maybe there's plans to add something up there eventually.
  12. JPP
    JPP Active Member
    SF Bay Area, CA
