Where we tend to stay when traveling the most (Timeshare from the secondary market, WorldMark), both the Las Vegas Blvd and Anaheim CA locations have 120V outlets.
Las Vegas, they have many in each garage, but, we found despite being 120V 20amp outlets, if we draw more then 10-11 amps, the voltage drop is too much.
Anaheim has 120V 15 amp outlets, and drawing the full 12 amps is not a problem, no voltage drops.
Las Vegas we were not staying long enough to avoid having to picking up some miles at the supercharger before leaving. Our most recent Anaheim trip, we had no problems getting to 90+ % before we left, and making it to the Indio supercharger.
I really like the idea of pushing 120V 20 amp (with appropriate wiring) for true long term locations, such as airports, off airport parking, resorts, and even hotels.
120V 15/20amp keeps you from having mileage loss over night, and gains a bit of charge. Commercial properties pay a demand charge based on peak KW draw. The higher power the EV charging setup is, the more likely it is to boost the property into a higher demand charge. For this reason slow and steady is the way to go for long duration charging
Longer term load sharing EVSEs will be the way to go, especially if they can get interfaced to the building peak usage, and know when to lower draw to help keep the building from hitting a new "peak" demand.
-Harry
