I can't help with the electrical questions, but as for trenching, I've done my fair share. How about replacing three underground irrigation systems (up to an acre), 15" below grade, on solid round river rock covered with a light dusting of blow sand? Forget the shovel, it's a nearly worthless tool for this job, it just means more volume to dig. Also, you can't easily use a machine to trench right up next to the house, when the rocks get too big, or there are large tree roots. Get out the narrow hoe, pick axe (here's an example: http://www.amazon.com/Truper-31614-5-Pound-Mattock-Fiberglass/dp/B000KL2V6A/ref=sr_1_1?ie=UTF8&qid=1436918951&sr=8-1&keywords=pick+axes), axe/loppers/snippers (for roots), and crowbar. Use two people to work from each side, and just dredge/pull the dirt out of the trench and you'll hardly need to even lift. Rocks are only difficult when they get over about 20 lbs, then you need to widen the digging or redirect. It sure beats going to the gym!One thing you can try - ask the electrician to quote if you dig the trench yourself.
I've had a subpanel installed in my shed, and the Electrician basically gave me a $800 discount for digging my own trench & then refilling it after.
Digging it required a $60/day trencher from Home Depot, and $2 worth of Ibuprofen for after.
It's required to be 18 inches deep (NEC 300.5), unless it's within 5' of the outside edge of a swimming pool or hot tub, in which case it's covered by article 680.
Since nobody else has mentioned it -- you probably want to get the gas company out there to mark where their line is located before using anything but a shovel to dig the trench. In most locations, it's a free service.
… as noted by CHG-ON local building or electrical codes may not permit aerial outbuilding feeds,
Here is my reaction -
First you are in CA and they have lots of code and regulation issues. Unless you live in an area where people do not hire inspectors when purchasing a house - you really need to think about the fact your house will be sold assuming it does not burn down or get wiped out by a tornado, etc.
Second 100 amp service has not been considered adequate for a long, long time. 200 is the minimum assuming you have things like AC, electric oven, electric drier, etc. == and I don't mean all of those power users - just some. Today many houses have 400 amp service (wires to the house), even if the breaker box is only 200 amps.
Third - looking ahead you might generally need to upgrade your whole house. The big expenses in that process are service to the house (wires and meter) and the circuit breaker box. If you plan on staying there and upgrading, it may well be a waste of money to just get the 14-50 installation - rather plan for the future and get started right.
Update!
Three ridiculous half days of jack-chiseling, jack-spading, trench shoveling, and even a little auger-foray for fun. Here's where I stand:
The main 13' trench is looking good. A few more hours of elbow grease and I should have it somewhat uniformly level and ready for conduit
Then I'll need to take my hammer drill and masonry bit and punch a hole under the ****** little planter wall so we can route the conduit under toward the garage.
Here's where I've run into a problem. The planter, about 2 feet in, has a "step footer" of some sort. This thing is solid as hell, my 35lb jack is barely leaving a mark. I am sort of at a loss now. The Tesla gods don't want me to be able to charge at home apparently.
Here's another shot depicting the different levels. We're pretty deep, at the start so thats not a huge deal, but as we approach the garage wall we're way too high for a comfortable trench.
Waiting to hear back from a mason friend on how to proceed. Initial suggestion would be to knock the planter wall out so I can jackhammer the remains of this footer with ease... Now I gotta know, what would the electrician have done if I just let him do all this?? We're quickly approaching "not-worth-it-land" and I might need to hire someone to finish. Oy.
:cursing:
@bruce
I could, but it adds bends to the conduit. Never got a max # from the electrician but I'm guessing more is worse
It'll be an exploratory dig, as the slag could go all the way through. If it was clear for a trench, say 8" over, I'd still have to come back and pound out that footer as I approach the garage. I guess that's less work than the entire length :crying:
I'm getting my electrician's opinion, but in the mean time, can anyone tell me why simply going overhead with a mast on the home and a mast on the garage is so expensive? So much so that everyone I've asked about it just says "its too expensive" and wont tell me why.
:cursing:
It worked great. I laid the conduit out straight on the lawn (50 feet) and pulled the wires (6 gauge) through the conduit. It was pretty easy to get the wires through the conduit when it was straight. After that, I buried it in the trench and didn't have to worry about how many bends or curves it had since the wire was already inside.
This might work for your problem. Just measure out the distance you need, install the wires and then bend the conduit any way you need to get it where you want.
Plenty of wire lubricant and a good fish tape and you can pull fairly easily
