Electricity is $5/gallon
Discussion in 'Model 3' started by 1.21GW, Jul 27, 2018.
  1. 1.21GW
    1.21GW Member
    Michigan
    At $0.15 / kWh, electricity costs the equivalent to $5/gallon of gasoline
    Just a random fact of the day. Enjoy
    * 1 gallon = 33.7 kWh
    ** Long range Model 3 holds just over 2 gallons of equivalent energy
    ***Luckily EVs are more efficient
    • Funny x 13
    • Disagree x 8
  2. marusan
    marusan Member
    Silicon Valley, CA
    If gasoline were $5/gal, I suspect ICE cars would start getting more efficient again.
  3. Daniel in SD
    Daniel in SD Well-Known Member
    San Diego
    The most efficient engines are only about 40% efficient though :p
  4. chronopc
    chronopc Active Member
    At $0.15 / kWh each mile in a model 3 costs about 3.6 cents.
    • Helpful x 2
  5. Robotpedlr
    Robotpedlr Supporting Member
    Seattle
    Based on that number, taking it a step further. Assuming an equivalent ICE car would get about 30/mpg. That means you are paying the equivalent of about $1.08/gal (30 miles x 3.6 cents). Which is similar to my calcs for my MS at 11 cents/Kwh. So MUCH better than $5/gal
    • Like x 4
  6. JeffK
    JeffK Well-Known Member
    Indianapolis
    If you had a large enough pre-existing solar installation plus storage then it'd be next to $0 / gallon. So there's that.
    • Like x 4
    • Love x 2
  7. Verynoice
    Verynoice Member
    Baltimore
    Those calculations are all fine and nice, but when was the last time you pulled up to a building in an ICE car and filled your tank for free?
    • Love x 2
  8. commasign
    commasign TeslaAdviceBlog.com
    Davis, CA
    $8000 for a 2kW solar PV system will generate enough electricity to drive about 15,000 miles per year for 20+ years. Let's say 20 years to be conservative (also the typical panel warranty these days). 20 years x 15,000 miles/yr = 300,000 miles. Assuming a 30mpg premium gas car equivalent, that would be 10,000 gallons of gas. $8000/10,000 gallons = $0.80/gallon.
    Ok, gotta factor in replacing the inverter at some point and decreased efficiency of the panels over time, and maybe you live somewhere that doesn't get as much sun, and maybe you drive a big "less efficient" EV SUV, and maybe we'll compare it to a 50mpg hybrid, but we're still in the ballpark of under $1.50/gallon equivalent even in the worst case scenario.
  9. SageBrush
    SageBrush REJECT Fascism
    New Mexico
    Too bad that power plants waste ~ 2/3 to make electricity.
    • Disagree x 2
  10. CricTic
    CricTic Member
    United States
    I can fill my ICE with 2 gallons of gas in about 10 seconds.
    YOUR MOVE TESLA!! :p
    • Funny x 3
  11. Zythryn
    Zythryn Model Y custom Warming Stripes wrap.
    Minnesota
    I think you mean “Just random bad math of the day.”
    • Like x 8
    • Funny x 2
  12. SageBrush
    New Mexico
    Yep, although it can be much cheaper.
    I paid 1/3 your presumed cost for top of the line equipment. My car runs 0.5 cents a mile to fuel. The same 30 mpg car would have to find gas at 15 cents a gallon to compete.
  13. gregd
    gregd Active Member
    CM98
    Your ICE can empty your wallet about 10 times faster than my EV.
    • Funny x 6
    • Love x 3
  14. Garlan Garner
    Garlan Garner Banned
    Chicagoland
    And then only use about a pint of it to actually move the car.
    I would challenge you to hook up your ICE exhaust through your bedroom window and have a good nights sleep.
    I can run my EV in my room.
    Your Move.
    • Disagree x 1
  15. SageBrush
    New Mexico
    #15 SageBrush, Jul 27, 2018
    This is too easy ...
    Two gallons, $6, say 50 miles range and 12 cents a mile
    I plug in at home, 5 seconds spent
    After a good nights sleep, I take the plug out: 5 seconds
    Up to 340 miles, 0.5 cents a mile
    • Like x 19
    • Love x 3
    • Disagree x 1
  16. brianman
    brianman Burrito Founder
    Ignoring vehicles and the overhead of preparing and delivering that gasoline for a moment...
    What's the most efficient consumer-available gasoline-to-energy converter that fits in a one-car garage these days?
  17. 1.21GW
    1.21GW Member
    Michigan
    Gasoline? 41% brake thermal efficient Toyota TNGA 2.0L engine in hybrid applications
    Diesels can do better, but the Toyota is leading the gasoline engines, Granted its peak efficiency is in a very narrow portion of the operation.
    • Disagree x 1
  18. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I can fill my Tesla every night in about 2 seconds. The time it takes me to plug it in, and for Free with solar.
  19. PoitNarf
    PoitNarf My dog's breath smells like dog food
    NJ
    If you’re thinking of getting a portable generator get a dual fuel one that works on gasoline or propane. Gas will go bad eventually, but propane can be stored indefinitely. Propane can also still be obtained in a power outage when a gas station pump would be inoperable.
  20. CricTic
    CricTic Member
    United States
    Well, that got dark pretty quickly.
    • Funny x 9
