So, the app and the new tiered pricing information are now available. Unfortunately it's expensive, even with the $4 monthly "Pass+" subscription. The tiers are for charge powers up to 75kW/125kW/150kW respectively. I looked up the rates for California and Texas:
California:
Without Pass+: $0.25/0.69/0.99 per minute
With Pass+: $0.18/0.50/0.70 per minute
Texas:
Without Pass+: $0.21/0.58/0.89 per minute
With Pass+: $0.15/$0.42/$0.60 per minute
At those prices it's at best an emergency option for Tesla drivers IMO. Too bad.
It's right in the post.Yeesh, per kwh ? minute ?
Sure, if such a thing was possible. Today, the driver has no control over the DC charging process. You can only adjust the amps on AC charging.Once the CCS adapter comes out you could actually throttle your car to 74kw charge speed, to get the most bang for your buck.
If your car tells the charger that it can accept a maximum charging power of 95kW, for example, it is placed in the “1-125kW” power level.
The power level set at the start of your session determines the per-minute price, which stays the same throughout the session.
It is not reasonable to charge based on what the car can take if the charger never actually delivers that. However, it seems that if you do actually exceed 75kW for 2 minutes, they will charge you the higher rate for the entire session, which is plenty bad enough. Depending on how long you need to charge, you should disconnect to stop the higher price and pay the session fee again to get enough charge to make it to your destination or the next charging stop.It gets worse. Just noticed this on their web page:
So each car will be charged based on the maximum power they can accept, not at what power you actually charge ...
On their web site it sounds like the car tells the charger the maximum power it can accept during the initial handshake before the session starts. If that's the case, you'll be placed in that tier even if you never reach the maximum (if you're in a SoC where the taper has started).It is not reasonable to charge based on what the car can take if the charger never actually delivers that. However, it seems that if you do actually exceed 75kW for 2 minutes, they will charge you the higher rate for the entire session, which is plenty bad enough. Depending on how long you need to charge, you should disconnect to stop the higher price and pay the session fee again to get enough charge to make it to your destination or the next charging stop.
If the car SOC is in the taper region, it will tell the charger the charging current it wants based on that taper, so the charger will never see a higher value that may be possible at a lower SOC.On their web site it sounds like the car tells the charger the maximum power it can accept during the initial handshake before the session starts. If that's the case, you'll be placed in that tier even if you never reach the maximum (if you're in a SoC where the taper has started).
I sure hope you are right, but I'm not so certain. For example, if you look at the Tesla charge curve, the power is also limited at the low end and only reaches the maximum at 10-15%. So if the car starts charging below the maximum and that's what's used to set the power tier, you'd potentially be placed in a lower tier and the charger would never allow you to reach the actual maximum.If the car SOC is in the taper region, it will tell the charger the charging current it wants based on that taper, so the charger will never see a higher value that may be possible at a lower SOC.
Once your EV is plugged in, your car will tell the charger the maximum power it can accept. This will determine the power level into which you’ll be placed, and the associated per-minute cost for your entire session. We automatically put you into the highest power level available at the charger that is compatible with your car’s charging capability.
Of course, EA could do stupid things in their software. However, if you plug in a Tesla at 2%, it will likely start at about 50kW, then ramp up to some maximum power at or above 100kW, depending on your vehicle. The logical thing would be for the charger to bill the entire session at the highest rate band that the charger actually delivered, whether it was exactly at the session initiation or not.I sure hope you are right, but I'm not so certain. For example, if you look at the Tesla charge curve, the power is also limited at the low end and only reaches the maximum at 10-15%. So if the car starts charging below the maximum and that's what's used to set the power tier, you'd potentially be placed in a lower tier and the charger would never allow you to reach the actual maximum.
Here's what their web site says:
EA needs to charge more for higher power levels because of utility demand charges. So, even if they could charge by the kWh everywhere, they would still need to charge a premium for high power.We need the state regulators to allow charging to be sold by the kWh. That would make this all much simpler.
An average price kWh could be arrived at then you pay "by the gallon".
You would never buy gasoline by the minute. Why buy electricity that way?
California:
Texas:
At those prices it would at best be an emergency option for Tesla drivers with a potential CCS adapter IMO. Too bad.
I just posted an article about the new app and prices. As someone noted earlier, they can be quite reasonable for someone the CHAdeMO adapter with an S or X.
Electrify America releases new app, big price changes
Made some quick plots comparing the EA prices with Supercharger prices, all converted to $/kWh depending on the charge power. For the superchargers, I used the rates from Tesla's web site ($0.28/kWh, $0.13/0.26 per minute in states with per-minute charging). If you stay between 50 and 75kW it's actually not bad (good for owners of the Tesla Chademo adapter, I guess).
Yet, someone using the CHAdeMO adapter on EA Pass+ may often end up paying less than $.28 rate and on the non-subscription rate they would pay only slightly more. Hardly 2-4x.The EA fees are still significantly (2x - 4x) higher than Tesla Supercharging...
Tesla no longer has “free” DC Supercharging for most of its new car buyers. In California (and the US generally) it now charges $.28 per kWh. In states that do not allow electricity to be sold by non-utilities using a per-kWh price, Tesla charges $.26 per minute at power rates above 60 kW and $.13 at power rates below that. There is no per-session or subscription fee.
