330 cca? for $100+K car, i would expect 1000cca agm battery considering how many electonics in the car rely on the battery.
ACK, CCA Does not matter at all for the Tesla. CCA is Cold Cranking Amps. We are not "Cranking" a ICE over. That is the only time CCA comes into play.
What we want are AH (Amp Hours). Amp hours are how long a battery can provide XXX # of amps for a certain period of time. Which is usually rated at 1 amp I believe. so a deep cycle battery, rated at 114 amp hours, should be able to provide 1 amp of power for 114 hours, or 114 amps for 1 hour (Although, due to inefficiencies and being able to get less power at higher draws, most likely a 114 ah battery would be able to provide about 70 or 80 at 114 amp draw for a hour-ish).
So the magic number, is the AH capacity of the battery. It could be 10 cranking amps, but as long as it can provide enough current to the electronics, and has a deep cycle capacity of enough amp hours, it's fine.
The odyssey battery above poster linked to has a AH rating of 28AH. That is fairly decent. Personally, my experience with Odyssey has not been a good one, and I will not be using their batteries any time soon. I have had great success with Batteries Plus Werker series Deep Cycles for Sealed Batteries, and Extremely great success with Walmart's Flooded Deep Cycle Everstart-Maxx Marine for flooded uses such as my EV Conversion. And Walmart has a warranty second to none. Unfortunately, they do not have a side that would fit a Tesla.
Although, anyone here have the Group Size or dimensions of the Tesla battery, I would really like it as I am looking into a Lithium Alternative.
