Yesterday I came across this story:
What's Inside the Deepest Hole in the World?
about the deepest drilled hole in the world, about 7.5 miles deep in Russia. At the bottom of this hole you will find 350f temps, 350f/177c! A hole in Germany saw about 600f/315c. The Russian bore was a huge and expensive undertaking, but is deeper than would potentially be needed, depending on the desired temperature and local geology.
One of the best renewable sources of energy has got to be, "liquid hot magma".
If holes like this could be drilled economically, you would have a massive source of steam for heat and electricity. Imagine a green house built on marginal land that uses water, heat, and electricity from the hole. It seems like an overlooked resource
that would be very reliable, rich, and durable. The consistency would act as a battery. Maybe there is even dissolved lithium in the water!
Here is some more info:
Ask Smithsonian: What's the Deepest Hole Ever Dug? | At the Smithsonian | Smithsonian
Thoughts?
Thoughts?
