The test results seemed more "empiracle" than "science".
A) Sample size of one.
It would be quite rare for there to be any significant differences between cars of the same model. In addition, more than one test has been reported in this thread.
B) One meter with limited bandwidth.
C) Meter not calibrated.
Strong assertions when you don't even know. Why would you have any reason to believe the meter wasn't calibrated? Or only testing a limited bandwidth? These were skeptical people looking for serious results. I have no reason to believe they would use equipment that didn't work.
D) Magnetic fields not measured.
Just because they had low readings doesn't mean nothing was measured. Are you suggesting the results wouldn't be legitimate unless they found much higher levels of EMF?
As far as your second question, I think I will chaulk it up to "human nature". I see both sides doing this.
Are you talking about the EMF issue? Can you provide examples of "both sides doing this" in this thread? I haven't heard anybody else demand a scientific study regardless of what "side" they were on. I don't even think there are any "sides." Did I miss something?
I will say, though, as time goes on and knowledge increases, many things that were considered "safe" turn out to be not so safe.
That's very true. What constitutes a safe level of EMF radiation is somewhat controversial and it's often hard to sort the truth from the hype. The tests mentioned in this thread indicate levels that are below anything considered a health risk by even conservative estimates. But I really don't think the purpose of this thread is to determine a safe level of EMF. You can decide that for yourself based on multiple other studies, using the test results that have been reported here. Keep in mind that CR found no correlation between hybrids and EMF levels. The highest levels appear to be from gassers. Oh, and they used a sample size of 1 for each model.:wink:
