bonnie
I play a nice person on twitter.
Doug,
You have posted over 10,000 times. And you seem to be advocating for Tesla at every turn. Do you work for Tesla?
Snarky!
Doug,
Doug,
No. I do not, nor have I ever worked for Tesla. I do not own stock in Tesla (though I was probably pretty dumb not to buy some). I do own a Roadster and Model S.
Tesla is not perfect and I have been known to criticize them on more than one occasion in this forum. On a couple of occasions I have lobbied them to change their policies (successfully in one case). However I do believe what Tesla are trying to do is very important for the world - not to mention pretty amazing technologically - and I am therefore a big supporter.
As for my recent contribution to this thread: I am offering my opinion, which is informed by my experience as a Professional Engineer who has significant experience with EMF fields, including shielding, interference, etc. It has nothing to do with my opinion for or against Tesla. It has to do with my understanding of the scientific principles involved.
"I have also done some EMF tests in the Model S and have found it is generally good, but found some increased EMF levels under the dash when running the electric heating (but not the seat heaters)."
What gauss number range do you consider "generally good" and what is the ceiling on this? What is the threshold gauss reading number that is generally bad?
You should measure which ever frequency range that scares you. You seem into this and I'd be interested to know which data you base any fears you're harbouring on. Also, previous measurements done in EVs generally show much lower EMF radiation over a wide range of frequencies as compared to ICEs and hybrids. (Not that it matters much either way, if you ask me).
I thought they used PWM at much higher frequencies to control power levels. If so, your example would only be true if they were applying full power or 100% duty cycle PWM in addition to max RPM.
I have performed tests on our Tesla using consumer grade EMF meters on a number of occasions and not found any EMF of any consequence.
Funny you mention Ahlbom and Feychting. When I studied medicine in Gothenburg, Sweden in the early 2000's I remeber that during our semester in Epidemiology and Scientific method we went in to great depth in this and Feychting's other epidemiological studies about cancer and power lines. These are observational studies and very prone to confounding factors and all sorts of bias, from observational to selection bias etc. In short let's agree that if these results could be confirmed in studies with better methodology there would be immense impact on society. But the results are not confirmed, but rather debunked.
As for your conspiracy theories... Well, each to their own I guess.
@Luxembourger: I'd encourage you to start by measuring fields in your current car to get an appropriate baseline.
Have you read the posts up-thread? You are not the first person raising this point, and others have already done measurements, e.g. EMF Radiation - Page 11.
Good to have someone with real empirical data,
What did your EMF meter show?
It is very rudimentary - Green / Yellow / Red type device which measures from 20 to 10,000 Hz, where:
Green is below 2.5 Milli Gauss
Yellow is 2.5 to 7 Milli Gauss
Red is above 8 Milli Gauss
The car is generally in the Green zone but I have seen Yellow with the heater running around the footwell area. I would note that my vehicle is a Sig and may not be representative of current production.
As noted above, we were getting Yellow readings when driving adjacent to power lines (which seems to suggest that the level of sensitivity is reasonably good).
.... for reference an MRI is ~5k - 30k Gauss... or 700k - 4.2M times the levels in a Tesla. If magnetic fields had any biological effects we would see them in an MRI... we don't.
'MRI does not use ionizing radiation (high-energy radiation that can potentially cause damage to DNA, like the x-rays used CT scans).
There are no known harmful side-effects associated with temporary exposure to the strong magnetic field used by MRI scanners.' - FDA
