End of Speed Limit - NY
Discussion in 'Autopilot & Autonomous/FSD' started by cdninnyc, Feb 6, 2021.
  1. cdninnyc
    cdninnyc X Driver
    Westchester NY
    I don’t see this much out of state, but in NY, every time a slow zone goes back to the state standard 55 miles per hour, the speed limit sign says “End of 35mph” or 40 or whatever the speed limit WAS. The car sees the speed limit sign as 35, not 55. The problem is this is almost always for 2 lane non divided roads, and Tesla AP limits to 5 miles over. This was NOT a problem when the data was from mapping, but since the change to visual speed limit detection, it’s almost always wrong. This is a problem in areas like route 22 in NY, where the speed is 55 with frequent 40 zones. It effectively means one cannot use AP for stretches as log as 10 miles at a time. I do this you’re weekly and it’s starting to be quite aggravating.
    I was hoping this would be rectified in a recent release but to date, nothing. I’m in a 2018 X with up to date software.
    Anyone else experience this? Ideas on how to get Tesla to fix? I am assuming CA doesn’t have these stupid signs so hey don’t experience the issue.
  2. HelixSpiral
    HelixSpiral Member
    Cincinnati
    Ugh. Totally ignoring Teslas/autonomous cars, this is the stupidest thing ever. Why put a sign for what the speed limit ISN'T? Just say what the speed limit IS.
  3. MrTuna
    MrTuna Member
    South Bend, Indiana
    School zones are always wrong here. I think it’s not a standard.
    sadly they need to map this for all 50 states. I wish we had better federal guidelines for this stuff. Do we really need different ways to label roads in different states?
  4. MD-2000
    MD-2000 Member
    Winnipeg
    Yeah, our school speed limits are signed - "30kph Mon-Fri 7:00AM to 5:30PM Sept-June"
    The "30" is recognized by the Tesla as a valid speed limit sign any time, but the end of school zones has a yellow sign containing a miniature white "30" sign and underneath in the yellow, the word "ENDS" - which of course the car does not recognize.
  5. run-the-joules
    run-the-joules Active Member
    SF Bay
    Better than "X mph/kph when school is in session", because how the F should I know if school is in session?
  6. CapsEngineer
    CapsEngineer Member
    Maryland
    You're not supposed to. How else are they going to make money?
  7. flyhighboi20
    flyhighboi20 Member
    flint
    Same problem in MI except there often isn't even a sign to say the speed zone ended, we just know if you haven't seen a speed limit sign in a while it's 55mph. I am really puzzled by why tesla has decided to make the default speed limit 45 when there is no speed limit data instead of 55 which is the national speed limit. So many roads around me are the default 55 and I can't use autopilot because it limits me to 50.
  8. Routybouty
    Routybouty Member
    Fort Wayne, Indiana
    Million dollar idea: attach a miniature 55mph speed limit sign to your wipers and wipe as necessary.;)
  9. flyhighboi20
    flyhighboi20 Member
    flint
    Maybe if they could just have a system similar to Waze. I used to be an active area manager on there and like many others would fix issues on the map, either things we saw or things people reported. I understand when you are dealing with a car that's "driving" and controlling the speed there would need to be some kind of verification but I think they could quickly get the maps and speed limit issues sorted as so many people are willing to help. Imagine reporting that your new subdivision isnt on the maps and the next day you get in your car and the entire sub is built out or your car was limiting you to 45 because it had no speed limit data and you report it and the next day on your drive to work you can use AP because it now shows 55mph.
  10. MrYenko
    MrYenko Member
    Fort Lauderdale
    The car knows what the speed limit is at all times. It knows this because it knows what the speed limit isn't, by subtracting what it is, from what it isn't, or what it isn't, from what it is, whichever is greater, it obtains a difference, or deviation. The guidance sub-system uses deviations to generate corrective commands to drive the car from a speed where it is, to a speed where it isn't, and arriving at a velocity where it wasn't, it now is. Consequently, the speed where it is, is now the speed that it wasn't, and it follows that the speed where it was, is now the speed that it isn't. In the event that the velocity it is at is not the velocity that it wasn't, the vehicle has developed a variation. The variation being the difference between what the speed limit is, and what it wasn't. If variation is considered to be a significant factor, it too, may be corrected by the GEA. However, the vehicle must also know where it was. The vehicle guidance computance scenario works as follows: Because a variation has modified some of the information the vehicle has obtained, it is not sure just what the speed limit is, however it is sure what it isn't, within reason, and it knows what it was. It now subtracts what it should be, from what it wasn't, or vice versa. By differentiating this from the algebraic sum of what it shouldn't be, and what it was. It is able to obtain a deviation, and a variation, which is called "five over.”
