Ending "Tire Anxiety"
Discussion in 'Model S: User Interface' started by joefee, Mar 20, 2015.
  1. joefee
    joefee 3M+ page views on TMC Threads
    It's great that the coming OTA update will cure "range anxiety" but what about "tire anxiety"!!! The software wizards at Tesla can make the car drive itself but can't tell us what the tire pressure is in the tires .... I hope that we get a cure soon and add a dummy light for rotating the tires while you're at it and oh ya, how about APA (auto pothole avoidance). :wink:
  2. ChadS
    ChadS Petroleum is for sissies
    The solution is simple. Sell your hulking behemoth and get a Roadster. It will tell you the tire pressure in each tire all day long. Yeah, I don't know why they went backwards on the Model S.
    And believe me, when you are in a Roadster, you automatically avoid all the potholes. Ugh. (The car seems to be fine after hitting them, but man does it make a nasty noise).
  3. jcaspar
    jcaspar Member
    Sacramento
    I have a little had held gauge that tells me the pressure in each tire. You can get one at any tire store..:smile:
  4. billarnett
    billarnett Member
    Emerald Hills CA
    The roadster also tells you the temperature in each tire.
  5. joefee
    If they had temp and pressure capabilities in the roadster why oh why can't they roll that out in the Model S! Elon can you hear me....
    @jcaspar Using a tire gauge is like using paper maps for Nav!
    @ChadS I've had Roadster loaners and while lots of fun, after hitting a few pot holes and butt fatigue after 60 mins of driving, I'll stick with my "hulking behemoth."
  6. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    #6 Btrflyl8e, Mar 21, 2015
    Just get Michelin Tweels.
  7. Dborn
    Dborn Confirmed
    Sydney, Australia
    No blowouts here, but you certainly get blow through!!!
  8. ChadS
    I used to go on a lot of road trips in the Roadster, and I was happy with the ride. Until I got a Model S...yeah, now I don't want to take road trips in the Roadster anymore.
    The Model S has about a zillion practical advantages, but yeah the tire pressure thing is one way I appreciate the Roadster.
    I wish both cars could watch the tires for inside wear; I've been surprised before as I checked the tires and thought I was fine, but because the car is so low I only really saw the outside but the inside was totally worn out...
  9. krisg81
    krisg81 Member
    This is one thing I don't miss about my P85!
    After 7K miles the rear insides of the tires (on staggered wheels) were completely destroyed! Bald insides but the rest of the tire had plenty of tread left. Complete garbage. Hopefully this isn't an issue on my new P85D.
  10. jerry33
    Texas
    That is an alignment issue. The tires had toe-out rather than toe in.
  11. krisg81
    krisg81 Member
    Maybe you should call the Tesla service center and speak to the techs that aligned it twice to factory specs, or the various other people with same exact issue as you seem to know the solution to the problem..? Also, it would be a negative camber issue not a toe problem.
  12. jerry33
    Texas
    1. Camber exacerbates any other alignment problem (similar to how speed exacerbates damage in a collision even though it doesn't cause the collision). Obviously if you have less negative camber you will get better wear because it will be less sensitive to the other factors.
    2. Tesla has changed their alignment specs several times, so it depends on which "factory specs" they are using.
    3. They use alignment machines which can be programmed wrong or can be out of calibration.
    4. They are, in general, doing a better job than they were a year ago.
    5. The only way to really solve the problem is to get adjustable linkage and use either a reputable frame alignment shop or one that specializes in race cars. Those places typically have people that actually understand alignment. Note that there are some Tesla Service Centre personnel that understand alignment, but they are constrained by head office in what they can do.
    And yes, my Service Centre knows how I feel about this.
  13. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    I had my car aligned four times in 2013, twice in 2014 and once in 2015. The most recent alignment was this past January and was the best one so far. Our local service center replaced the alignment bench they had in 2014 with a newer and better one. Service manager said it was the best one they could buy. I asked them to lean towards more toe-in on the front and rear, but within Tesla specs, to aid straightline stability. My car feels much more stable than it did after the prior alignments.
  14. BerTX
    BerTX Supporting Member
    Texas/Washington
    Isn't this topic about TPMS inadequacy?
  15. gzerninplatz
    gzerninplatz Member
    Troutdale, OR
    fobotire TP monitors - alert to smartphone when tires go above or below your preset number...and graphic display of pressures whenever you like...
  16. JohnQ
    JohnQ Active Member
    Redding, CT
    Tire anxiety is getting low pressure warning on a road trip, not having a spare, and wondering whether you simply need a top up or something more serious going on. Added to my fun yesterday while eking out the last of my juice on the way to the Brattleboro SC.
  17. AmpedRealtor
    Buckeye, AZ
    And not something a Tesla owner should have to resort to. This is a basic feature.
  18. gregincal
    gregincal Active Member
    Santa Cruz, CA
    I have one of those too, but I wonder if it's broken. Every time I open the glove box and glance at it, it still reads 0.
  19. joefee
    Happened to me on a trip from California the Denver was a total false alarm!
  20. N4HHE
    N4HHE Member
    Madison, AL
    Is my understanding Tesla has not changed alignment specifications. That sometime in 2013 completely wrong never right for anyone specs got in the Hunter database. And Hunter equipment is used at the factory. So everyone got an exact alignment to the wrong specs, over and over again starting at the factory until the problem was found. Problem was fixed by the time my 85 was built in December 2013. At 13k miles my 19" tires are wearing very evenly.
    It shouldn't be hard to find the correct numbers for alignment on this site to verify whoever is doing your alignment is using the correct specs.
    Years ago an idiot at Firestone aligned my 1986 VW Golf ti 1984 VW Rabbit specs. It was a fright to drive in the rain.
