Past couple ride I have noticed what I think is a strange software bug. If the car is on level ground and at constant speed my energy consumption will register as zero on the consumption graph. If I accelerate or am driving on an incline it will register something but once back on level ground It will drop to a steady 0 wh/mi and stay there. So because of this I am seeing crazy efficient drives on a cold soaked battery in 20 degree weather with the heat set to 70. I'm assuming it is a software bug however rebooting has not solved the problem. My only concern is that it may be somehow affecting the BMS in how it calculates things but my rated range I think appears to be still showing correctly so far for the most part. I've never seen anything like this happen on any Tesla I've driven. The problem makes the energy graph useless so I'm hoping to it goes away quickly. So far I've made bug reports while driving and also called Tesla to see if they would want to check anything on the car remotely but over the phone the kind of blew it off and set up a service appointment. I'm sure they are getting plenty of calls about energy consumption with the flood of new owners but I doubt anyone is calling because consumption is way too low. Going to stop by the SC in person to see if they want to check logs quick before going through with dropping off the car for what might be a simple software bug.
Aside from a software bug can anyone think of what would cause something like this, a faulty sensor or something?
Software Ver. 2018.50 7e49f8a
