Hi all,
On my S60 dash, I have driving stats (charge, miles, etc) on the left side and music on the right side. I've had this set up for a couple of weeks (S is 2 months old) and this past week, the energy graph with a (!) shows up intermittently on the right for a few seconds, and then goes back to the song title. It's happened 3 times so far:
- once it showed up when I got in the car @ around 5 AM, and it was a bit colder than normal
- two other times, it showed up while I was driving on an uphill (same spot, 2 different days)
I have been taking the same route to work for the past 2 months so it happens some times but not the others. I have to double check but my wh/mi was about 300 at the time, I think. and it only shows up briefly and then disappears. when i switch to the graph permanently, the ! indicator is not there.
I also did some searching around and it isn't the tire pressure indicator - that shows up right above the right hand side display. This is a ! in a triangle that shows up right to the top left corner of the energy graph and looks like it is part of the graph display vs. some other indicator.
I tried looking around and reading but could not find any info on this. Does anyone have this happen to them and can they share experiences... mostly interested if this is just me accelerating up the hill or if the cold weather impacts this, or if this is something I should call service about.
Thanks!
Gabe
Thanks!
Gabe
