In this sketch 10 numbered tubes will be mounted permanently on a seesaw in Horizontal direction .There will be 10 numbered 100 gram mass Iron balls and these Iron balls will move in these tubes. we will attach two piston generators (linear generator) on the both end of each tube as per diagram.we will take a motor and this motor will work to shake this balanced seesaw in horizontal direction towards 5 centimeter (thrice in a second) back and forth .
I have used a running car example in this design .Suppose a car is running at the speed of 100km/hour and there are 10 numbered passengers in the car then each passengers speed will be also 100 km./hour.
Here in this design passengers are tubes Containing balls, car is balanced seesaw and speed is turning of seesaw.
I did some experiment before posting this article to know the feasibility of this design.
I took a clicking based writing pen and changed its spring with some other spring and put some 700 gram weight on the tip of this pen to know the force if I want to press the pen to write .I found that I will have to apply 0.7 Newton force if I want to write something with this pen .
Now I took a cylindrical shape object having mass of 86 gram( consider it 100gram) and put it in a rectangular shape box .The length of this box is 8 centimeter and length of object is 4 centimeter.
I attached two pens with the both sides of this box and turn it 15 centimeter with 3 newton force and noticed that the 86 gram object is pressing the tip of the both side pens or in other words working equivalent to 0.7 newton force on each side pen.
Now replace these pens with generator.
Input force is 3 newton(Overall) .
object is hitting with each generator with 0.7 Newton force .
Total generator are 20
so overall force applying on total 20 generators is 0.7*20= 14 Newton
If we consider 70% efficiency of these generators then the out put will be 9.8 watt (consider it 10 watt).
So now tell me where I'm wrong ?
I again say that there is need of some work on it and without collaboration and team work it will be not possible to build it and test it.
