My understanding is that the leak wasn't in the engine but on the test equipment. Could be incorrect but if I'm right then the issue has nothing to do with the engine and should be an easy fix. Seems to also tie in with SpaceX's claim that this will not impact any schedules.
Guess we'll find out eventually.
That's very speculative. Depends entirely on what caused the leak. It could have been an issue with the test stand itself, or it could be a design flaw with the engine. Could also be a manufacturing issue.
The problem is that while engineers always expect that tests could have failures, the schedulers don't. This is certainly going to push out this portion of the Block 5 qual. Whether that is the long pole in the schedule or not will determine if the overall schedule is affected. Their claim that it won't be indicates that they either have some float in the schedule or that this qual test wasn't a critical schedule driver. As an outsider, there is no way to know for sure. My guess would be that it will have an effect on something else, particularly with how over-worked the SpaceX team already appears to be.
