zanary
Could you please elaborate?
Can we not install a spliter for the power there?
More to the point, I'm not that concerned with their policy is but I want to continue to be able to draw power for my dashcam from where it current gets power near the microphone area. Can someone explain how easy it is to have a splitter so that the security option can be added while retaining power to the dash cam without extra wiring issues?
I assume the security option uses very little power?
This will be an important issue for folks installing third-party or non-original upgrades. I have a 4-channel Blackvue 750 setup, which uses T-Tap connectors, which snap over the 12V wiring, penetrating the insulation to provide a connection (a "vampire tap," which leaves the cable and its connector otherwise intact). I am also preparing to install the new sun visors, which include LED-illuminated vanity mirrors, and hope to tap into the same power source for those. I'd like to get the Enhanced Anti-Theft Upgrade as well, which would plug into the connector, leaving me with three systems running off of the same power source. I am hopeful that the Service Center would choose to tolerate/overlook the use of T-Taps for the dashcam and visors. The concern then shifts to the wiring and fuse for this circuit, to ensure that the installed systems are not drawing too much current.
(1) My Blackvue is spliced into the 12V cable, so that one cable is feeding both the new Enhanced Anti-Theft system and my Blackvue.
(2) The microphone speakers are position differently in this version.
(3) For some reason there is now a new connector just idle sitting there. I didn't see this before. I have a 2017 Sept build Model S P100D.
Check out these detailed pictures I just snapped. One showing the new part, one zoomed into the splice for my Blackvue, one showing the new microphone placement (look carefully for the different shade in the outside of the grill at the angels, and the last image is of that new connector which I haven't seen before, so no idea what this is for...
