Yeah, in terms of "better", there's no consensus that Micros or a single SE will be better/worse in terms of energy.
To me, the trade-off is in terms of what happens when an inverter fails. If you have 30+ micros on your roof, it's likely at least 1 is going to fail in the years after install during the useful life of the system. So when one goes offline, you get to weigh whether or not replacing it is worth the labor/time to send someone up on your roof to swap one micro. The warranties for labor typically expire pretty fast. So while the actual part may be warrantied for 25 years, you're looking at out of pocket costs to fix it. So then you're sitting there thinking maybe you'll just wait for #2 or #3 to fail before you replace a bunch in one go.
But with SolarEdge, there's a reasonably high chance the single inverter is fine for the useful life of the system. But of course if you are unlucky and it fails, it could take your whole array down with it. And as we've seen repair turnaround can last a few days or a few weeks/months if you're really unlucky.
