Error ID 1456, what does it relate to?
Discussion in 'Roadster: Technical' started by JOEV1, May 16, 2017.
  1. JOEV1
    JOEV1 *****joe
    Salzburg/Austria (The Sound of Music)
    After I was "pushing" going uphill a bit harder, I had the Message "Power System Service required" (together with "FAULT")
    I could not find ID 1456 in any listing. (cooling of HV and Battery?)
    Car drives and charges normally. When dismissing message it goes away but comes back after a while.
    Perhaps someone in the forum had this experience as well.
    Thanks for any responce.
  2. JOEV1
    JOEV1 *****joe
    Problem solved!
    The Fuse Nr. 23 (10A) was blown. Maybe the AC Compressor for the cooling circuit pulled a bit too high a current.
  3. hcsharp
    hcsharp Active Member
    Vermont
    Where is that fuse? In the fuse block with all the others?
  4. JOEV1
    JOEV1 *****joe
    On the Passenger side behind the small removabele cover next to the glove box.
    The Labels for the fuses are on the back-side of the cover.
  5. JOEV1
    JOEV1 *****joe
    Right next to the glove box. Located somewhere in the middle of the Fuse panel. Refer to the rear of the Lid which covers the fuses.
