Error while charging
Nick70d
133
65
St.louis
I have this errors while home charging
ckoval7
Mild One
Sep 19, 2018
662
599
Maryland
Your car is in limp mode. Best limp over to the nearest service center if it's not too far away.
When you open the errors on the center screen by pressing the red warning triangle at the top, what are the error codes?
Reactions: Nick70d
kindred7
20
7
Canada
Are you handy and have access to a voltmeter? Open the frunk and check your 12V battery voltage. Should be more than 13v if the DCDC is working properly.
It's weird but my car did this back in November after what seemed like an update. I was doing something else at the time so I disconnected my 12V for about 10min. When I reconnected the problem went away and hasn't come back since. Also, around the same time others were complaining about 12V batteries and or battery heaters. Not sure if there's a connection but I guess its worth a try.
Reactions: Nick70d
BrokerDon
1,394
1,283
Newport Coast, CA
My 2015 P85D with an original 12V, 55k miles, 98% gen1 Tesla Wall Connector charging nightly to 90% at 40A/240V exhibited the same error after what seemed like an update too. I reported it to Tesla and scheduled an appointment at our local service center. Diagnosis couldn't find anything wrong and I haven't seen the error since... so hoping it was just "a glitch in the Matrix". or "digital termites".
Nick70d
133
65
St.louis
Ok I will try it tonight
Nick70d
133
65
St.louis
Seem like it, after the update 2020.4.1, 43k miles, drove home from work, plug charge with wall connector , then after 20 min ,i went back to the car to get something out, then i notice the error.,
Have not check the 12v battery yet. But i notice the regen is gone while driving with those errors
Nick70d
133
65
St.louis
I just test the 12v battery its showing 12.43v
Is it the time to change new 12v battery?thanks
