Escort Redline Install
perkiset
... this one goes to 11
Jan 7, 2014
238
0
Phoenix, AZ
First want to take a moment to thank the many folks here that have helped with detector installs, particularly CHG-ON who sent me a couple *excellent* private messages with the specifics of precisely what he ordered to do his Valentine install.
I chose the Redline because of its detection range, and also because it does redlight and traffic cameras which, unfortunately, have been a bit of a problem for me ;) Also, I didn't want a lot of wires all over the place, so I needed a detector with a well-designed Bluetooth connection to my phone. There are many threads here on the board that will tell you how to install a detector, there were just a couple things that I wanted to add because I couldn't explicitly find them.
Electrical Details:
I chose to connect my detector to the Power Steering 5A fuse, because it comes on and goes off with the car when you're ready to drive. It is the middle 5A fuse in the driver's-side fuse box. I purchased a mini-fuse splitter, got another 5A fuse and all was good. Note that the top doesn't fit so well anymore, but I chose not to cut it to make room - rather, I just pushed it down to snug and let the vanity panel keep it in place.
Second was the ground. Using a VOM one can clearly see that virtually every metal piece in the fuse area is grounded, as woulc be expected. I chose to ground to a non-structural bolt that holds down the Frunk assembly. Here are photos of both the fuse and ground (just before I finished tightening and cleaning the groun):
Note also how I stretched the power cable from the Escort smart block. This is how Escort does bluetooth. I purchased a normal 12v extender, plugged the smart connected into it and cut off the 12v male end to make the electrical connections Some threads have show the power connector down over the drivers wheel well, under the Frunk, but this has also gotten a bad rap for getting wet. So pulled (somewhat) tight and under the fuse block panel seemed to me to be a drier solution.
Finally, I chose to wrap the escort in a freezer baggie, like a christmas present with the "fold" underneath the device. Then using "Extremely Strong" double sided tape (thanks Home Depot) I secured the escort the right of the solenoid that opens the frunk and under the wiring for the nose cone sensor. Here's that:
I set the volume to mute on the box itself and range to Auto, thinking that would be all I got, but the app is excellent, giving me full control/telemetry from the box. So I also purchase a magnetic window holder for my iPhone 4+ which is snuggled all the way to the left, in the middle of the windshield.
Took it out for a test and it was detecting traffic cams at several hundred yards before the interesection. Excellent! Found a by-the-road "van unit" traffic camera, and it only detected it at probably 50 yards - I know those cameras use incredibly low power to avoid (me, heh) but this seemed REALLY close. Don't know if I was getting warned before I would've gotten hit. but it was at least good to know that it saw the radar, which is considerably better than my older Escort and a baloney Cobra detector.
Once more, thanks all for the assistance.
Awesome hints and even better photos. Thank you so much for the shout out.
I do worry about water intrusion. You ARE in Phoenix, but haven't you been soaked lately with ridiculous rains? Maybe cutting a slit so that you are not stressing the cord and then a touch of silicone could protect you. I have had failures due to trying to cram wires in before.
Love the freezer bag! I did something similar, But yours looks better. Just waiting for the onslaught of El Nino to see if it survives, If not...well $500 down the drain.
PS: I Love your handle.
Totally my pleasure, I really appreciate the time you took with those PMs. Made me feel much less concerned about getting into it.
The power cable is doubled-back in the fold, then the whole mess was electrical taped to keep water out. Agree that it's a concern, but given your tips, I think I have it pretty well locked down. Particularly your note about the connector, when over the drivers wheel well getting wet. So my smart block is actually in the fuse area, which I do not think gets wet. So there's no exposed electronics in any area where there could be a splash. All that said, I'll probably pull it all open and have a look after our next rain. And that said, are you kidding me? I have an old ICE for driving in the "rain" - don't need to get Nick all dirty ;)
Normal baggies, left in the Phoenix heat dry out, crack and go away in a season or so. I've found that the freezer baggie material is considerably more durable, hoping to get a full season or even 2 out of it before I refresh. It looks like some water definitely gets up there behind the nose cone, but I think I'm at least as well protected as the connectors for the sensors in the cone. I *think*. As you say, time will tell :/
Thanks mate - a play on my name, my nick as a musician about 30 years ago and a comment from a friend. Been with me in the Internets since about 1999.
Cheers CHG-ON, thanks once again for the assist.
Ok - You got me. I just ordered everything. The Bluetooth wireless connection to my cockpit makes the installation seem simple/quick enough for me to do. I would like laser shifters, rearview mirror display, and such but that all seems like way too much work for me to do and the few hour job would turn into a few day job.
