They use the EPBB Calculator.Okay, how is PGE calculating this? What is this statewide methodology? How do they estimate PV generation?
Since I lost a lot last month, just wanting to know how they calculate month by month, assuming it changes?
Thats great, but none of that stuff was sent in to PGE, so nothing to use. So, how are they calculating the number? All panels best angle? No shading? Or all panels worst angle and max shading?They use the EPBB Calculator.
See https://www.pge.com/includes/docs/pdfs/shared/solar/solareducation/ebpp_calculator_explanation.pdf
The interconnection application is supposed to include everything in the linked PDF. That is all the data anyone needs to make a good estimation of system production.Thats great, but none of that stuff was sent in to PGE, so nothing to use. So, how are they calculating the number? All panels best angle? No shading? Or all panels worst angle and max shading?
You have an example, when say everything. In my NEM app were panels, inverter stuff. But nothing on orientation or shading.The interconnection application is supposed to include everything in the linked PDF. That is all the data anyone needs to make a good estimation of system production.
Seems there is no 100% clear process of what they use to approve. But I am happy.I did not look at the details of the EPBB calculation, but in my recent application they used the square footage times a factor to go with a number. If that is not sufficient to justify my current application I now have two months af actual usage including charging two Teslas and my wife baking a lot. That cosumption was over 1 mega Whrs and would justify an even larger number. This is Phase One for just the Grid Tie. Phase Two will be more, but it will be behind the meter and self consumed so I do not have to ask PG&E for permission.
That is what I am worried about, shall see. But since I have lots of panels in poor directions, and shading, I might be okay. Meaning, the most I will get out of my about 30KW of solar is 22.8kw, and I have never even seen that.My interconnection application had this data. It was not complete the first time so PGE rejected it until Tesla re-submitted it.
The EPBB calculator WAY underestimates actual production. You'd for sure be better of installing an NGOM if there are times you're going to be away from home with things off otherwise you'll lose credit.
h2,That is what I am worried about, shall see. But since I have lots of panels in poor directions, and shading, I might be okay. Meaning, the most I will get out of my about 30KW of solar is 22.8kw, and I have never even seen that.
At this point, I believe I may have enough over production compared to my use I have not used the hack again. Batteries do not get back to 100% so I pull from grid during peak. Will see if this approach works.h2,
The form used to apply for solar NEM includes tilt, azimuth, location, number and model of panels, see below. I don't see a shading correction, but I think that is OK for us.
https://www.pge.com/pge_global/comm.../interconnection-renewables/Form_79-1151B.pdf
I don't think you need to worry abut them overestimating your production. The estimate is only used to limit the amount of export for which they credit you. Since you alway produce less than their estimate, no harm done. The reason they do it at all is that PG&E really does not want you putting more kWh on the grid than you solar is estimated to be capable of producing.
One way that might happen is charging a battery from the grid at off peak, and then dumping it back onto the grid at peak. At current EV2-A rates, that'd be .35 - .18 = $.17 per kWh, $2.29 per full PowerWall per day, ~$67 per month, over $800 per year of illegal NEM credit per powerwall engaged in this energy arbitrage. At that rate, one could pay for a PW in what, maybe 15 years? Not an attractive ROI, so it is mostly just paranoia on PG&E's part. PG&E has an exclusive franchise to buy kW cheap and sell them expensive. In larger installations they do require certified meters on the solar production which report directly to PG&E, so this estimation thing is pretty OK for us. But it is why we get the "complex" (i.e. incomprehensible) billing.
In other news, as you know I have solar, but using my "hack" since the cloudy weather several weeks ago, I have been charging my PW from the grid after midnight every night, and then discharging to run the house after 3PM when the rate goes up. When it is sunny enough, my excess solar production still goes out to the grid, and because I'm still on NEM1 gets full retail credit, so it exactly offsets the cost of what I drew to charge the PW. The newest version of the Tesla app fixed the bizarre grid flow numbers, though the hack still makes the app show solar production and export as zero because it is added to the grid numbers. Anyway, grid charging is alive and well, and saves me a few $ even when it got cloudy a few weeks back.
SWView attachment 738824
Not sure anyone filled out that form completely. I still have not seen another true up change because of my latest panels, so not sure what is happening. As long as I get full credit for generation, do not care. But next april when I am producing TONS, will see.
That's too small. Panels are far as you can see is what you need.Time for...
Crazy Floating Renewable Energy Gizmo
New device gilds the offshore renewable energy lily with wind, solar, and wave power all in one modular, scalable package.cleantechnica.com
I am assuming that PG&E has your panel array and orientation numbers from the PTO application as the calculator matched up to the information on the black bill for me. CSI EPBB CalculatorOkay, still trying to understand how PGE is doing when all they got was the number of panels.
So I just talked with PGE solar and verified they have the correct 3 PTO's for solar and batteries. There number of panels are fine. But I expected more generation credit based on I produced more I think that the number they have. (Since I do not know the actual days they used, I am guessing somewhat) But, since I have so many panels like half of them facing north, I know they do not produce much this time of the year. But if PGE assume they were all facing south,, ...
So has anyone gotten from PGE or somewhere all the specifics that PGE has, and has been able to put into the formula, and cross check?
Installation specifications
• Mounting Method
• Tracking Type, Tilt, Azimuth
Equipment make, model and quantity
h2,Okay, still trying to understand how PGE is doing when all they got was the number of panels.
I never filled anything out. Never saw anything from the installer. This is why I would like to know what PGE has for my account but ...I am assuming that PG&E has your panel array and orientation numbers from the PTO application as the calculator matched up to the information on the black bill for me. CSI EPBB Calculator
Edit: The PG&E Checklist https://www.pge.com/pge_global/comm...ction-renewables/InterconnectionChecklist.pdf does mention the following.
Because they limit the amount they will credit you based on the approved PTO panel count. So if one puts more panels on, and does not get permission, you do not get credit for anything more.h2,
Remind me why you are concerned about PG&E knowing details of your solar.
Also you mentioned earlier about true-up date change. My understanding is that only happens when you get permission to operate with a battery. I believe they are not supposed to do this, but their excuse is that they switch you to "complex billing", and that somehow justifies changing the true-up. Adding more solar or storage would not trigger a true-up date change I believe.
SW
