It's poorly researched garbage full of misconceptions.It is not a matter of "dangerous" when an article is accurate - it is honest.
The US electric grid will not support a complete replacement of ICE vehicles with EV's and plug-in hybrids today or probably in 20 years. While some studies are suggesting there is sufficient capacity available from our power plants, it is the distribution grid capacity to the houses, commercial buildings, service stations, etc., that would require the multi-$T upgrades.
The cost of operating an EV per mile is the highest of any alternative solution - by a factor range of 3 to 6 compared to a comparable advanced diesel vehicle for example.
We have research statistics to estimate the average number of minutes a US citizen spends in a car per day and 31 minutes/day was a common conclusion. The concept that people would consciously make the decision to deplete the supply of critical rare earth and heavy metal minerals needed for wind turbine manufacturing and other renewable technologies to manufacturer a vehicle that they only drive for 31 minutes per day for a 7 year life cycle does not seem like a responsible trade-off. Such a turbine, in a good wind resource, with the same amount of minerals is likely to generate Green Energy for 10-14 hours per day for 30 years. A comparable advanced diesel vehicle requires far less minerals and heavy metals. For more information about this mineral usage issue please review the article:
All batteries experience energy loss even when sitting idle - unused. This is common knowledge and common experience.
Energy distribution on the electrical grid typically has a double digit line loss between the power plant and the home. This inefficiency needs to be calculated into the true energy cost of operating these electrified cars regardless of whether the car owner is paying for the line loss. This is far from Green.
Advanced battery technologies have the very real potential of exploding in a collision. To protect our fellow drivers and emergency response service personnel, all vehicles that contain these battery technologies need to be well labeled with large warning stickers on all surfaces that the vehicle contains a battery that may explode in a collision or if the jaws of life are used in the wrong place.]
In a serious vehicle accident, fluids are leaked - and in some cases sprayed - out on the road, road sides, on other vehicles, on drivers, on passengers, ... The chemistry of a lithium battery is rated as "low-toxic" which still requires a licensed HAZMAT cleanup. Actually, the current battery in the Prius is rated "high-toxic" and is extremely dangerous. In comparison, an advanced diesel vehicle in the future will use B100 biodiesel which is rated non-toxic (1/10th as toxic as table salt) and can be hosed off with just water with no ill-effects. Over the coming years, antifreeze will again be sourced from glycerin (99.9% pure) as it was before WWII, so future diesel vehicles will be far less toxic than EV's and plug-in hybrids.
Replacing liquid fueled vehicles with electric powered vehicles directly increases the most health impacting emission particulates into the air and our oceans - heavy metals from coal burning power plants. So while the over-all volume of emissions from EV's is lower than gasoline and petroleum diesel vehicles, US power plants are primarily coal powered (please do not argue the majority is now NG - while the NG capacity may be in place, actual energy generation is still primarily from coal) and so an increase in electricity generation for EV's is worse from a health perspective than emissions from 2nd generation feedstock sourced biodiesel powered vehicles by 3 orders of magnitude (the emissions of one EV that is recharged from a coal powered plant have a greater negative health impact than thousands of advanced diesel vehicles burning B100). Very simply, until EV's are only charged from renewable sources, they will be the direct catalyst for the health issues and deaths of many more people.
So soybeans or other biodiesel crops, fall out of the sky? How about all of the energy that is used to manufacture the equipment, diesel/gasoline used in order to harvest it/transport it to the plant. Then more resources for the equipment used to get it to the filling point, and then the equipment used to dispense the stuff. Oh and dispensing biodiesel also uses electricity. Where is this info on your site?
Who cares? Effectively a 700 mile trip is an event that most people never take, and the ones who do might do it once a year. Rent a car, take a train, or fly. Don't buy a vehicle for the less than .01% of use, buy it for the 99.99% of use.
This is not "honest" today's Tesla could fill on this trip in less than 7,5 hours."
I believe your calculation is suggesting that there would be a 220V/high amp charger available at exactly where one would need to charge on this 700 mile trip? This is not a reasonable expectation today nor likely 20 years from now. Liquid refueling stations are not available where you need them either - which also effects travel time and the number of refueling stops one must make. In the case of a diesel - many diesels - 700 miles is the range from a single tank and it only required 6-8 minutes to load that energy source into the vehicle.
"Wow that article is bad. My favorite is that they imply that it takes 630kWh to drive 700 miles in an EV. Not 2,200 miles."
While there are certainly variables based on different vehicles, these numbers were derived from an actual real-world test of a Mini Cooper E.
"Oh and the $9k-$15k transmission replacement after 100k miles. That is rich too. Specially when all the EVs they mention are single speed."
Actually, your statement here is twisting the original communication. Have you evaluated the replacement cost of a Prius Hybrid Plug-in transmission? For most EV's, the "transmission" has been replaced by sensor arrays and computers controlling independent motors. Have you evaluated the cost of replacing this I/O control system on a Tesla?
"And I always hate that Bio-Fuel hacks never account to how we are going to grow the Biomass. My milk is already expensive enough. Ethanol is making our food prices absurd."
Actually, our website contains a great deal of information about how the world IS growing the 2nd generation feedstock for biodiesel. We are on the same page regarding 1st generation feedstock for biodiesel and ethanol.
