"False. T&D for the grid is around 7%, of course the customer pays for it."
Having worked at the world's largest electric utility for several years in data analysis, I will beg to differ.
"False. Of the thousands of EV's on the road not a single one has ever exploded, let alone even caught fire, in an accident. The Volt battery in NHSTA testing never exploded."
The NHSTA test resulted in the battery catching fire. I was a PI for a DoD UAV project - Lithium batteries catch fire, explode and their materials/fluids spray out. It is ugly.
"False. Lithium batteries have little to no free liquid in them."
You are correct with "little" (I have modified the statement to include materials). The materials of a Lithium Ion battery is still rated toxic which requires a HAZMAT cleanup.
"A Prius does not use lithium batteries but NiMH."
That is correct - not sure why you are making this statement - our article does not state that a Prius uses Lithium (yet).
"No records exist of the thousands of Prius's in accidents spilling battery chemicals or causing hazardous spills."
How politically correct of you to state it this way. You must realize that chemicals from a Prius battery have, in fact, been leaked in an accident.
"Lithium cells pose even less of a risk."
Biodiesel is less toxic than table salt, is virtually non-flammable and is sustainable. EV's are not sustainable - unless you want to discuss the use of minerals from Mars. Have you researched what minerals and the amounts that are necessary to build EV's? Where do these minerals come from? Where are they mined? How many Chinese died to mine these minerals? EV's are far from Green.
"False. Coal is only 45% of the US grid."
Allow me to share the following - the typical coal plant generates electricity at .024/KwH vs. NG at .52 vs. wind at .12/KwH vs. solar at .18KwH. You can believe what you want to believe - I am sharing the facts with you.
It's also much easier to capture emissions from a single generating plant than millions of ICE vehicles."
Correct, but since the emissions from a vehicle burning B100 from 2nd generation feedstock "cleans the air in metro areas while running" - this is a positive item. EV's do not clean the air.
"Further, it is more efficient to simply burn biomass in a large generating plant to charge EV's than to process and refine it into fuel to burn in inefficient ICE vehicles."
Not even close. The energy conversion loss by your method is staggering. EV systems (not just the EV) are only about 45% efficient while the complete B100 from 2nd gen feedstock system is about 65% (with start/stop tech). You need to catch up - your arguments are out of date.
