etcgreen - can you properly quote your posts so that your posts are a bit more readable?
You seem to omit the fact that growing plants can only be done in the very low single digit efficiency range. We simply do not have enough land area to perform a large scale transition to biofuels. Only algae biofuels might be able to overcome this limitation - but these have been 5 years out from commercial operations for quite some time now.
In comparison electricity from solar PV is easily had TODAY with 15% efficiency and 20%+ if you're willing to pay a little bit more.
Biofuels will be a niche market for applications where a very energy dense energy carrier is required (long-haul trucking, airplanes).
Well - if you have data showing different losses - please share them. Otherwise, I fail to see how anyone besides the customer pays for line losses - the utility co surely doesn't pay for them.Having worked at the world's largest electric utility for several years in data analysis, I will beg to differ.False. T&D for the grid is around 7%, of course the customer pays for it.
The NHTSA test only resulted in a fire because they neglected to conduct proper protocol after the crash. Never mind that GM had addressed the cause of the fire (which was not directly related to the cells themselves, but a coolant leak causing a short in electronics). Never mind the ~200k automobile fires a year - they explode and materials/fluids spray out. It is ugly. There is a good reason the NHTSA does not crash cars with fuel in them.The NHTSA test resulted in the battery catching fire. I was a PI for a DoD UAV project - Lithium batteries catch fire, explode and their materials/fluids spray out. It is ugly.False. Of the thousands of EV's on the road not a single one has ever exploded, let alone even caught fire, in an accident. The Volt battery in NHSTA testing never exploded.
You seem to be quite selective in your hearing as it's quite possible to build EVs without any special minerals compared to ICE vehicles as others have noted.Biodiesel is less toxic than table salt, is virtually non-flammable and is sustainable. EV's are not sustainable - unless you want to discuss the use of minerals from Mars. Have you researched what minerals and the amounts that are necessary to build EV's? Where do these minerals come from? Where are they mined? How many Chinese died to mine these minerals? EV's are far from Green.
OK - so now we know what it costs to fuel an EV per kWh based on plant generation type. How much does your biofuel cost?Allow me to share the following - the typical coal plant generates electricity at .024/KwH vs. NG at .52 vs. wind at .12/KwH vs. solar at .18KwH. You can believe what you want to believe - I am sharing the facts with you.
Hah - I've never seen anything burn that clean unless one cherry picks a pollutant. Let's see total emissions, eh? It's well known that NOx emissions are generally higher in biodiesel burning cars than regular diesels.Correct, but since the emissions from a vehicle burning B100 from 2nd generation feedstock "cleans the air in metro areas while running" - this is a positive item. EV's do not clean the air.
How about some actual numbers behind your percentages?Not even close. The energy conversion loss by your method is staggering. EV systems (not just the EV) are only about 45% efficient while the complete B100 from 2nd gen feedstock system is about 65% (with start/stop tech). You need to catch up - your arguments are out of date.
