Etox Zafer Electric
Discussion in 'Electric Vehicles' started by vfx, Feb 7, 2011.
  1. vfx
    vfx Well-Known Member
    CA CA
    http://green.autoblog.com/2011/02/07/etox-gets-a-diesel-detox-will-unveil-electric-prototype/
    edit:
    Can some fix my typo in the title? Thanks!
  2. doug
    doug Administrator / Head Moderator
    And I read that as, Exxon Safer Electric... o_O
    Fixed.
  3. Jaff
    Jaff Active Member
    Grimsby, Canada
    Very nice looking vehicle...if they can deliver the 250 km range, and keep the price under $25k, it might "blow the leafs away"... :wink:
  4. domenick
    domenick Nerd
    Florida
    I'm not sure the new car is based on the Zafer even though the original source seems to say it is. The price of the 4-cyl diesel version of the Zafer is over twice what they say their electric vehicle will cost.
  5. Jaff
    Jaff Active Member
    Grimsby, Canada
    #5 Jaff, Feb 8, 2011
    Interesting to hear this domenick...if this is the case, it sure sounds like something is wrong with the EV's "costing" numbers..."if it sounds too good to be true"...
  6. domenick
    domenick Nerd
    Florida
    The price quote came from the head guy in the company and I'm pretty sure there wasn't a translation malfunction there. Pretty damn inexpensive, as electric cars go. From here I'd just say, let's see what they bring in 3 months and, if it seems worth it, hope they can move forward on this product. It doesn't seem as if they built very many (if any) examples of the Zafer.
  7. Eberhard
    Eberhard #421 Model S #S32
    Germany
    It looks like, not only TESLA can do inexpensive battery-pack. Recently i ask for a quotation to deliver 100.000 chinese 18650 cells at 2200mA. The price tag was 20cent per piece. 6831 pcs = 1366.20 USD
  8. Jaff
    Jaff Active Member
    Grimsby, Canada
    Eberhard, just curious...is there a difference in quality with the Chinese 18650's or have you used them in the past with success so this isn't a concern.
  9. Eberhard
    Germany
    #9 Eberhard, Feb 8, 2011
    Jeff, do you think todays chinese cells are worse then the quality cells used by ac-propulsion in their t-zero 2003? that was 8 years ago? Todays quality cells cost should be well below one USD
    But assembling the batterie pack is more complex. That may be the reason, why TESLA moved from Thailand to California.
  10. qwk
    qwk Model S P2681
    It was Taiwan.
  11. TEG
    TEG TMC Moderator
    #11 TEG, Feb 8, 2011
  12. Eberhard
    Germany
    Thailand?
  13. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    #13 Lloyd, Feb 8, 2011
    Probably Numi (Tesla-Toyota) plant in Fremont, CA (My guess only!)
  14. domenick
    domenick Nerd
    Florida
    Thailand.
    At those Chinese prices, one could sell assembled 30 kWh packs all day long to DIY guys.
    So Martin...100,000 cells...you doing up a dozen cars of some sort?
  15. Eberhard
    Germany
    Using a robot on higher volume, like for the Model S, is inexpensive and fast - even quality is higher. As an result the battery-pack gets less expensive. It not the cells - it's the work of assembling and quality-control which is cost intensive.
  16. domenick
    domenick Nerd
    Florida
    Good point but I'm also pretty sure cell price has come down quite a bit. So anyway...about those 100,000 cells...
  17. Eberhard
    Germany
    cells are cheap only 25$ per kWh not 500-1000$ per kWh as often published
  18. Jaff
    Jaff Active Member
    Grimsby, Canada
    #18 Jaff, Feb 9, 2011
    Actually Eberhard, I was asking your opinion about today's (non-Chinese manufactured) cells vs. today's Chinese manufactured cells...in your experience, is there any difference in quality or are they basically congruent?
  19. TEG
    TEG TMC Moderator
    Martin? Forum user "Eberhard" is not "Martin"... Different person I assume. I think it is a somewhat common name in Germany. http://en.wikipedia.org/wiki/Eberhard
