[EU] What the charger "needs"?
Discussion in 'Model S: Battery & Charging' started by Eumox, Nov 3, 2013.
  1. Eumox
    Eumox Member
    Austria
    #1 Eumox, Nov 3, 2013
    I drive my Model S since Sept. 20, 2013. Up to now it works like a charm. I usually charge with my newly installed 400V outlet outside the house. No problems yet.
    This weekend we went for a trip to visit my wifes parents, 330km away. I did a full charge and we cautiously went 100km/h on average (partialy autobahn). We arrived with another 112km to spare.
    It was late and I went to bed without plugging in. The next day I tried to charge with their 400V / 16A (CEE red) at the back of their farm house. They usually plug in an electric mill over there. It is a farm in eastern Austria, near the hungarian border. I was baffled to see that the Tesla box on the charger cable didn't light up at all. No green or red light at all. The mill worked quite well with this outlet. I changed the charger cable adapter to Schuko 230V and tried another outlet in the garage, what we call "light bulb oulet" in the local tongue (roughly translated from "Lichtstrom"). At least it lit up but this time the Tesla box showed a red light. I went inside the house and tried another 230V outlet. The Tesla box showed a green light. We rolled out an extension cord and plugged it in again but the Tesla box went to red light again. I parked the car very close to the outside wall and we managed to pass the original Tesla cable throughout a window. Finally it worked. Charging took about 28 hours and the outlet was super hot afterwards.
    So my question is: Does anyone know what kind of measurements the Tesla box does on the line? What does it need?
    I am not exactly very tech savvy, but I understand what voltage, current and sine waves are. Do you have an idea in simple words what just happened?
    greetings
    Eumx
  2. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    look in the package that your owners manual is in, their is a charging information card. match the lights and flashing, to the trouble shooting chart. red flashing is usually going to be a grounding issue.
  3. Cottonwood
    Colorado
    I agree that it is probably a grounding issue.
    I'm sure that you can find the European UMC Users guide online, but here is a link to the U.S. version: Tesla UMC Guide, U.S.
    In addition, here is the decoder ring from that U.S. users guide for what the lights mean. The European version is probably similar, but...
    Good Luck!
  4. Eumox
    Eumox Member
    Austria
    Thanx for your answers. The table to decode the light signals is actually the same in my manual. So.. I would say that it seemed like grounding issues but I hope to get to a more detailed understanding of what it measures.
    The only working outlet (230v) functioned only without extension cord. I get that it showed a grounding problem.
    But I still find it very mysterious that "no lights at all" means "Power lost" while the electric mill still functioned on that outlet (400v). I did the test two times between the mill and my Tesla cable.
    Did anyone else ever experience that sensibility on the "outlet-quality"?
  5. LuckyLuke
    LuckyLuke Model S P90DL
    Eindhoven, The Netherlands
    Try to test the pins in the CEE16 socket with a volt meter, maybe you see something out of the ordinary there that doesn't match the voltage or frequency the charger accepts?
    http://www.teslamotors.com/de_AT/models/specs
  6. tubist88
    tubist88 New Member
    Germany
    Probably the neutral N is missing. Mill may run nevertheless. Check the voltage between a L and N.
  7. Eumox
    Eumox Member
    Austria
    Again, thanx for the answers. I'll transmit that info to my wife's dad. He will make someone check on that. Maybe it helps to turn their electric installations more safe :scared:
  8. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    Also, be aware, when using a regular (non 3-phase socket) the Model S wants Live and Neutral on the correct pins. So sometimes you'll have to re-insert the plug "up side down".
  9. Eumox
    Eumox Member
    Austria
    Cool. I'll try that next time
    thanx
