Europe Roadster adapter to Typ2-connector for use 43kW-charger
Stefan T
340
175
Sweden
- - - Updated - - -
Good luck to you. Such a device would be very popular. I looked into doing it a few years ago. My approach was to rectify the input, then feed it through an inverter. To handle a reasonable amount of power would have required a heavy device that took up too much space in the boot so I gave up on it. Maybe you have a better design?
That is what i think to do to but i'm not shore if i can do it small enough and not to Heavy
m0rph
660
255
Belgium
If I can follow correctly, you are talking about a 3ph->1ph isolation transformer? That already exists, rated at 90A but limited to 70A by the car. And it's very bulky indeed! Nlab.be sells these..
I was looking into this before I bought my CrOhm type 2 charger. The difference between 70A and 64A just didn't do it for me...
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
@markwj If they are pulling 13A on each phase and just connecting them in parallel, then the blue neutral/return wire on the car side of the EVSE needs to be sized to carry all 39A back again. It's difficult to tell in the photo, but is is fatter?
- - - Updated - - -
Not only that, but that "90 Ampere" charging station at NLab produces a really low voltage that after around 2 hours dropped below the threshold the car accepts and it cut out. I had to drop my car back to 55A in order to reliably complete the charge. I suspect their converter is not rated for 16kW continuous even though it claims to be 20.7 kVA.
We did look at making a 3 phase to 1 phase converter using GaN electronics. It would enable a smaller unit (shoe box sized for 16kW) but it would be costly. Otherwise the only way to do this right now if you *really* want three phase input is to fit the Brusa charger, but that has been discussed in other threads.
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
By the way, do you know where this one is located? (As my photos show, it's not the one from the NLab facility in Bruges)
hcsharp
3,370
1,335
Vermont
If I can follow correctly, you are talking about a 3ph->1ph isolation transformer? ...
Not quite, although that's a simple but not very portable solution. I was talking about using electronics instead of a transformer. Convert the 3 phases to DC, then use an inverter to produce a single phase supply. I found out later that a friend of mine actually built this but it took up half the boot and could only produce 20A continuous single phase. At 95% efficiency it also produced a lot of heat.
gregd
2,524
1,755
CM98
Wild and totally naive thought... Would it be easier to skip the inverter part, and convert 3phase into DC for a CHAdeMO interface? Then use the Jdemo box from Tony?
markwj
Moderator, Asia Pacific
Apr 10, 2011
4,583
1,179
Hong Kong
Yes, the blue wire is fatter than the other three. The 40A Tesla wall connectors in UK should be the same arrangement. Grateful if you could try Henry's new type II CAN on them to see what happens.
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
This is already done in the form of "portable" 22kW CHAdeMO chargers. They are still rather large and expensive.
Mobile Fast-Charger MDC22
- - - Updated - - -
If someone with one wants to let me know where I can find one, then sure.
It'd be interesting if the car receives a 40A pilot and then tries to pull all 40 through one phase.
m0rph
660
255
Belgium
No i don't have a clue. I was trying to find pictures of the NLab installation, but only came across this one on their site..
simonog
433
61
United Kingdom
@hcsharp: Henry - can I get a type 2 can from you for my UK roadster? Can collect when I'm in the US to save international shipping/
on a different general topic, for the record the early UK Model Ss were delivered with dual chargers even if only one was paid for. The reason was Tesla needed to support the standard 32A domestic single phase charger and their EU charger module is only 16A 3-phase.
The software then prevented the second charger being used when connected to 22KW 3-phase unless the charger upgrade fee was paid.
rewiring Type 2 wall chargers was not acceptable as those then would not have charged other makes of EV.
after a year Tesla came up with a cheaper solution for single charger cars: a relay pack which as stated upthread just connects the car's three 16A phases in parallel when single phase 32A is detected as the input.
Reactions: GSP
ElectricLove
551
312
"There is a slight risk of putting a little more leverage on the charge port with my adapter, but it's quite small. This is the shortest adapter I've made and when you add the length of the Type 2 connector the combined length is only a few cm longer than the OEM charge connector. I've got over 100 CAN adapters in circulation and not one has ever caused any damage to a charge port."
It did damage my charge port, if you recall... However, I was using it with a slightly larger stack; I did the CAN SR -> Tesla/J1772 adapter -> J1772... So I added one more thing to the mix, but it broke pretty quick, I think 2nd or 3rd time using it...
hcsharp
3,370
1,335
Vermont
I assume the point of your post is to warn people that using a product in a way that's not recommended or supported increases the risk of damaging your car. That is only one reason why I don't support stacking adapters, and not the biggest reason.
BTW, this thread is about the implementation and use of the CAN EU (European Type 2 to Roadster) adapter, not the CAN SR.
