Try it and leave Sentry mode on. That should tell you how other people feel about it.There are around 4 EV (podpoint) charging Points at the MK Stadium near the cinema. Is it poor form to park in one of these spaces and leave the car on charge while I watch a film? (They are only 7KW chargers)
If you have access to home charging I would kind of agree but if you rely entirely on public chargers then I don't see it makes any difference whether you are on 20% or 80%. Either way you will have to get all your electrons at public chargers at some point so might as well be whenever and wherever it is most convenient. Overall you will spend exactly the same amount of time sitting in charging bays.I have a golden rule - only ever use a charge point when you really need to charge.
I've used a few 7 kW destination charge points, usually overnight, when I've needed a full charge the following morning. When I owned a PHEV, I never once used a public charge point, for the simple reason that I never NEEDED to charge, I always had enough range to go wherever I needed to without any charging at all - charging was just a "nice to have" feature that improved economy when the car was parked at home/"work", with access to a charge point that no one else ever needed to use.
Charging points are there to be used, so use them. That's literally what they're for. Every 30 minutes you spend charging is 30 minutes less you'll have to spend next time. It all evens out in the end.
There's nothing more infuriating than being close to empty and having a car with a 240+ mile range hogging the charger.
What’s been your experience using destination chargers e.g at hotels?
You turn up and they’re full but need a charge for your onward journey the next day.
"needtocharge" is one of them. that just uses the regnum I thinkI only ever charge on Destination Charger / A/C if I need the charge, in case someone with smaller battery / greater need needs it. Like an Outlander
I have a card in the car with my mobile number on it that I can leave on the dash : "It you urgently need a charge please call me"
There are websites which offer similar ability (i.e. to avoid disclosing your mobile number), I think they make use of a QR code
