Everyone here seems to appreciate data, and I've been curious how accurate EV Trip Planner is in estimating energy use for the Model S. I just purchased a P85D and since the EV Trip Planner website does not have a profile specific for that model, I was even more curious to see how the this site would work for my car. Here's how I did the comparison:
EV Trip Planner site
EV Model: Model S/P (21" wheels)
Speed multiplier: 1.0
Cabin temp: 36 deg F
Exterior temp: 36 deg F
Payload: 300lbs
Payload is high. I'm 220 and there is probably only another 10-15 lbs in emergency equipment in my car, but there you go.
Car variables
The exterior temp according to my car was 31-37 degrees. I didn't use any climate control. Kept the driver side seat heater at level 2 and only used the rear defroster for about 10 minutes. Glad I remembered to bring a jacket!
I used cruise control to exactly match the average speed listed in the "Details" tab of EV Trip Planner which meant at times I was going slower than necessary on city streets but I wanted to be as accurate as possible. I accelerated gently when leaving a stop light or stop sign and when passing a truck.
Results
From my place of business to the Casa Grande supercharger (to test out charging there) was 38.3 miles with 230 feet of net elevation change (472 up and 243 down) according to EV Trip Planner. Actual mileage was 38.5
Total energy used (estimate): 14.3 kWh (374 Wh/mi)
Total energy used (actual): 15.2 kWh (395 Wh/mi)
% over estimate total kWh: 6.29%
% over estimate Wh/mi: 5.61%
From Casa Grande supercharger to my home was 57.0 miles with -115 feet of net elevation change (462 up and 577 down) according to EV Trip Planner. Actual mileage was 57.4
Total energy used (estimate): 20.6 kWh (361 Wh/mi)
Total energy used (actual): 21.1 kWh (367 Wh/mi)
% over estimate total kWh: 2.43%
% over estimate Wh/mi: 1.66%
Some conclusions that jump out at me:
1. The P85D can be driven in a way that energy efficiency is close to the P85.
2. The P85D seems to use more power climbing than is estimated for the P85. I think this data is inadequate to draw much of a conclusion, my guess is that the P85D is more power hungry climbing than a P85
3. EV Trip Planner seems fairly accurate even though there is not a P85D specific profile. I think I can trust it when I travel to Los Angeles this month.
Most importantly, it took a lot of discipline not to drive this car the way it wants to be driven
Payload: 300lbs
Car variables
Results
