EV Watch for Tesla, watchOS 2.0 app
Discussion in 'Model S: User Interface' started by fact200, Apr 4, 2016.
  1. fact200
    fact200 Member
    San Francisco
    Thanks for testing out on iOS 10! Reminds me that I should try it out too!
  2. fact200
    fact200 Member
    San Francisco
  3. fact200
    fact200 Member
    San Francisco
    Updated to version 1.13 to work with iOS 10 and watchOS 3.0.
    EV Watch for Tesla on the App Store
    Featuring continuously updating complications and crown support for setting charge:
    [​IMG] [​IMG]
  4. fact200
    fact200 Member
    San Francisco
    1.14 Released expanding on its focus on Apple Watch 3.0 and at-a-glance info:
    • iPhone Today Extension support
    • Expanded complication support: Large modular and Large utilitarian modes for info beyond charge level
    • iPhone independence (after syncing login token info and in presence of wifi)
    Other unique features:
    • Charge reminders
    • Complications that continuously update throughout the day
    EV Watch for Tesla, Apple Watch/iPhone/iPad app
  5. Alain13
    Alain13 Active Member
    Zoetermeer, Netherlands
    Bug report:
    When using the big complication on the Apple Watch, The In en Out temps are in F instead of C.
  6. fact200
    fact200 Member
    San Francisco
    Thanks for the report! Should be an easy fix.
  7. headcase
    headcase Member
    Raleigh, NC
    Loving this. Great work! :)
  8. Muzzman1
    Muzzman1 Member
    Los Angeles
    I like it too, great work @fact200
    Is there any way to set apart the battery compilation? Make it look "cooler" that the plain ring with percentage? Maybe have the percentage glow on/off alternating with a Tesla logo?
  9. headcase
    headcase Member
    Raleigh, NC
    +1
  10. fact200
    fact200 Member
    San Francisco
    There's some leeway for graphics in the complications. Probably no pulsing/animations though. Will have to play around with it.
  11. Alain13
    See attachment, the text below the graphics is always cut off no matter where I place the widget. Maybe also a 'European' only bug?
    BTW love the widget! (Even without the text ;))
      File size:
      333.8 KB
      13
  12. fact200
    fact200 Member
    San Francisco
    Interesting. Mind sharing which iPhone model that is? I'm having trouble re-creating the issue.
    Thanks. I was able to reproduce this by changing my system accessibility font size to one step smaller than the default (the smallest setting). Workaround for now is to bump this size up a little in your system settings. Will try to put out a fix for this along with the C temp display in the complication soon.
  13. Alain13
    Thanks for the info. I'm a beta tester, so I can always check it before releasing it if you wish.
  14. fact200
    fact200 Member
    San Francisco
    Awesome! new beta version is available which should fix both issues.
  15. Alain13
    Both Widget and Complication are fixed now! Thanks!
    Is it possible to detect if you have a pano roof or not? Because I do not have one and then the space can be used for other info/function. Also with the full glass roof I think more comes are coming without a pano roof, so maybe make it a setting?
  16. fact200
    fact200 Member
    San Francisco
    Yeah, I was thinking for non-pano roof owners I would put in charge state on the large complication which also states whether or not it's plugged in.
    For the main watch app, I'll probably just remove the picker.
  17. b00st3d
    b00st3d Member
    New Orleans
    +1 for removal of pano roof for something else...I'm a model x owner!
  18. Alain13
    Found another 'bug' while the car was charging. The large complication shows:
    235/16 3.7kwh
    It doesn't take into account that it is three fases. I have a 11kwh (235v * 16a * 3 fases) outlet at home.
  19. fact200
    fact200 Member
    San Francisco
    Thanks! Should be fixed in the latest beta drop.
    For those sitting on the fence, app is on sale for $0.99 through the end of the month.
  20. Alain13
    It doesn't show the charging rate now, so I guess you can call it fixed. ;) :p
