Even better look (maybe) at the Model 3
Discussion in 'Model 3' started by igotzzoom, Aug 7, 2015.
Tags:
  1. igotzzoom
    igotzzoom Active Member
    Mission Viejo, CA
  2. stopcrazypp
    stopcrazypp Well-Known Member
  3. igotzzoom
    Mission Viejo, CA
    Drat, and double drat! Was so excited for a moment. Guess we'll have to wait 'til March (at least).
  4. ryanjm
    ryanjm Tesla Podcast Host
    San Francisco, CA
    The car in the far right of the pic looks like a Model S, no? It's much wider than the half-sedan/half-CUV Model 3 and it definitely resembles the S...
    I will say I HOPE that right-most car is a 3, because it looks low, wide, and sexy under that cover.
  5. RobinF
    RobinF Member
    Houston, TX
    Why would they have a rough clay model of a Model X car nearly in production?
  6. gjunky
    gjunky Trifecta: Solar and both cars are EVs
    Scottsdale, AZ
    And in the video (60 minutes Australia) they were scrapping some clay from it so I assume they don't care anymore.
  7. wallet.dat
    wallet.dat Member
    SW
    I suspect that the covered car on the far right is the Model 3 sedan. The "weirdmobile" half-n-half is simply the two variants (CUV and sedan) derived from the same Model 3 platform, siamesed for whatever reason. The exposed car on the far left is just an early Model X clay.
  8. TEG
    TEG Teslafanatic
    Not TOO wide I hope. I would trade some interior room, appearance, and cornering stance, for the ability to fit in compact parking spaces comfortably.
    I appreciate that many mid-sized cars (like Prius, LEAF, etc.) are < 70" wide.
  9. stopcrazypp
    Ditto on that. The Model S is an extremely wide car, hopefully the Model 3 doesn't repeat that.
  10. Red Sage
    Red Sage The Cybernetic Samurai
    Los Angeles CA
    1) OP: That is not Model ≡.
    2) Model ≡ is bound to be wider than contemporaries from BMW, AUDI, and Mercedes-Benz.
  11. Vitold
    Vitold Active Member
    NM
    Increased width has advantages (safety, stability, storage) and Tesla can afford it due to added rigidity from battery. However, increased width adds weight. If battery pack will occupy floor space as it in MS width and wheel base will be a function of battery pack size at maximum capacity.
    With that said, if motor's are to be interchangeable between platforms (which makes sense), motor size/mounting may dictate minimum width.
  12. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    Increased width also increases drag, due to a greater frontal area.
  13. gregincal
    gregincal Active Member
    Santa Cruz, CA
    I don't expect it to be less than 70" wide, but still substantially less than the Model S.
