Science fan
This paper from NREL has some great info about calendar degradation. Based on this information I will try to keep the SOC of my Model S as low as is practical.
An HVB stored at 80% SOC and around 27 C will only last 10 years. An HVB stored at 60% SOC would have to be around 32 C to only last 10 years. At 27 C it will last much longer. The basic summary: keep the HVB as cool as possible & with the lowest SOC possible (within reason). Calendar degradation is going to be a larger part of total capacity loss than cycling degradation for most EVs. Keeping the HVB SOC as low as possible will add years to the lifetime of the HVB. The battery lifespan is defined as 80% of original capacity. However, don't let the SOC get too low, as this will damage the HVB due to increased stress on each cell as they have to provide the same amount of power with a lower voltage, thus necessitating higher amps (current) which causes more stress due to the internal resistance.
I plan to set my daily charge limit to 60%. If I expect to be driving more than about 75 miles in a day, then I will increase the charge limit so that I don't let the SOC (and thus the cell voltages) get too low. But ideally I will keep my SOC between 40% & 60% most of the time.
By managing the HVB SOC intelligently you can easily add 5+ years to your HVB lifespan. Considering the cost of the HVB, this seems like a smart move to me.
Good post, Hybridbear. The data you provide seems to be for an uncooled battery system. Is it true that our batteries are cooled while plugged in? If so, can we look forward to longer battery life, even if the ambient temperature averages 32 degrees C? Is there a standard temperature that our batteries are cooled to while plugged in?
