Ulmo
That is a nice parking lot: lots of good concrete spaces. No awful asphalt. I hate all the car ruining curbs, though.
Press release said it was supposed to be done in June. They don't respond on twitter.
Anxious to see a fast charger here or in Barstow.
All the Bolt Fanboys @McRat we're planning their trips to Vegas based on this charger opening. Just think of all the money they will save! Maybe even enough to buy a Model 3...
RT
Why would Bolt owners need a Model 3?
It's a good thing Bolt drivers don't actually need to charge in Baker in order to drive to Las Vegas today. A full charge in Victorville does the job.All the Bolt Fanboys @McRat we're planning their trips to Vegas based on this charger opening. Just think of all the money they will save! Maybe even enough to buy a Model 3...
RT
$22 is not that bad for a full "tank of fuel".EVgo charges $22/hr for current CHAdeMO -- I shudder to think what this will cost.
Perhaps. I think an hour of CHAdeMO charging yields about 100 miles? Roughly the equivalent of 4 gallons of gasoline at $5.50 a gallon. Maybe that's not bad in California -- haven't been there in a while.$22 is not that bad for a full "tank of fuel".
We're talking about the next generation of chargers here in Baker, so presumably people that can use that station would get something more than 50kW. Anyway, running today's Tesla CHAdeMO adapter at 125 amps for an hour should give you about 150 miles of range, not 100. Looks like you're using 25mpg equivalent, so that's $3.66/gal, which is exactly what Regular gas costs in Baker today. Also, a non-Tesla driver that uses fast charging more than twice a month in California should be paying EVgo for the $15/mo plan that reduces the price to $6/hr. In that case, 600 miles per month only costs $39 and the equivalent cost is $1.625/gal.Perhaps. I think an hour of CHAdeMO charging yields about 100 miles? Roughly the equivalent of 4 gallons of gasoline at $5.50 a gallon. Maybe that's not bad in California -- haven't been there in a while.
I guess we all have different experinces. Mine are that real, not theoretical, CHAdeMO chargers give about 95 A or 30-32 kW. Granted, I don't have a lot of experience. That is what the one EVgo charger I used provided. Right at 100 mph.We're talking about the next generation of chargers here in Baker, so presumably people that can use that station would get something more than 50kW. Anyway, running today's Tesla CHAdeMO adapter at 125 amps for an hour should give you about 150 miles of range, not 100. Looks like you're using 25mpg equivalent, so that's $3.66/gal, which is exactly what Regular gas costs in Baker today. Also, a non-Tesla driver that uses fast charging more than twice a month in California should be paying EVgo for the $15/mo plan that reduces the price to $6/hr. In that case, 600 miles per month only costs $39 and the equivalent cost is $1.625/gal.
Sure, that can happen. There are a lot of different CHAdeMO chargers out there and they have different limitations, both by design, and by environmental or maintenance influence. Some even shut down when they overheat instead of slowing down.I guess we all have different experinces. Mine are that real, not theoretical, CHAdeMO chargers give about 95 A or 30-32 kW. Granted, I don't have a lot of experience. That is what the one EVgo charger I used provided. Right at 100 mph.
Some EVgo chargers that only output 100A are made by BTC, are physically larger, and have a large display screen showing voltage and amperage during charging. The other typical EVgo chargers are made by ABB, are less wide, have a smaller screen that doesn't show voltage and amperage on the screen, and outputs up to 125A.I guess we all have different experinces. Mine are that real, not theoretical, CHAdeMO chargers give about 95 A or 30-32 kW. Granted, I don't have a lot of experience. That is what the one EVgo charger I used provided. Right at 100 mph.
Thanks! Do they all shut off at 30 minutes, forcing the payment of the $5 start fee again, or do the ABB ones keep working longer without having to go back to the car every 30 minutes to restart?Some EVgo chargers that only output 100A are made by BTC, are physically larger, and have a large display screen showing voltage and amperage during charging. The other typical EVgo chargers are made by ABB, are less wide, have a smaller screen that doesn't show voltage and amperage on the screen, and outputs up to 125A.
I think some people have claimed to get up to 48 kW or so using the Tesla adapter at 125A. At least that is my impression -- I haven't seen it in person. That was likely on an S85 or larger pack that operates at a somewhat higher voltage range than the smaller Model S packs.ABB shuts off after 30 min. also. That's what EVGo has in Austin. It never gave me more than 40kW, usually in mid 30's, and I only gained 60 miles in the 30 minutes. This was when I tried it soon after installation when they weren't charging for it yet.
