The NSW DCFC grants recommend (but do not mandate) that “Sites will need to provide a minimum of four adjacent parking spaces to host public EV fast charging. Ideally, these spaces will be accessible to EV drivers 24 hours a day, 7 days a week”
From one of the Arena Knowledge base articles.Are there available stats for time of day/ week people tend to charge? And for how long?
I'd hope they exclude data from non-24x7 sites entirely!From one of the Arena Knowledge base articles.
(But they recognise limited data points)
Can't find a similar statement in the Arena guidelines for the funding round where these chargers likely came from.The NSW DCFC grants recommend (but do not mandate) that “Sites will need to provide a minimum of four adjacent parking spaces to host public EV fast charging. Ideally, these spaces will be accessible to EV drivers 24 hours a day, 7 days a week”
Ultra Fast Charging Data Analysis Webinar Materials
On 5 August 2021, ARENA hosted an Insights Webinar on Electric Vehicle Ultra-Fast Charging.arena.gov.au
Wow.. they snuck that one out.. I live in Ballarat and drive past almost Daily and never saw this go in.. it’s not even in PlugShare..
Looks at least a bit trailer friendlyWent today, hidden out the back behind Shell and Oliver’s.. very good spot
It's not actually out of order though. If you see one out of four like that it generally means someone has plugged into it but not started the session yet, or something like that.Warrenheip already:
Similar to the way that the if the CCS2 port is in use, the corresponding CHAdeMO port will say "in maintenance" even though it's really just unavailable while the other port is in use.
That is less a UI issue than it is an API issue.That’s terrible software writing if that’s the case. Software engineers should take instruction from the UX experts, and not think they know better, and present meangingless or engineering text to the end user. A message like “Unavailable - Other Port In Use” would be much more informative, because ”in maintenance” could mean that port won’t work until a tech visits in 3 weeks’ time.
It's an issue of interfaces.That’s terrible software writing if that’s the case. Software engineers should take instruction from the UX experts, and not think they know better, and present meangingless or engineering text to the end user. A message like “Unavailable - Other Port In Use” would be much more informative, because ”in maintenance” could mean that port won’t work until a tech visits in 3 weeks’ time.
I’ve always seen it work as described in your second paragraph - as soon as you take one connector out, it immediately sets that one as “in use” and the other as “in maintenance”. Agree with others, a better description could be used!It's not actually out of order though. If you see one out of four like that it generally means someone has plugged into it but not started the session yet, or something like that.
It's only difficult if you're trying to use the correct charger. Like this.Admittedly by the same clock, Northbridge is difficult to access 38% of the time
