Vendor EVS Motors now a dealer for Redwood Motorsports Premium Suspension Parts for Tesla Model 3 and Model Y
EVS Motors
Global Vendor
Sep 3, 2013
2,143
523
Houston
Listings
EVS Motors is proud to be a dealer for Redwood Motorsports. Like all the other brands we sell we will only select and offer the best products for our clients. Not the cheapest, but only the best. We are catering to clients that want the best performance products for their money at an affordable price. There are no other brand products for the Tesla Model 3 that uses Ohlins like Redwood Motorsports does. If you haven't heard of Ohlins than you are missing out. They are one of the largest supplied to OEM suspension components, Motorcycle racing and automotive racing applications. Ohlins can be found in cars like the Pagani or in the fastest motorcycles like Ducati. We are super stoked that we are able to offer these products to our Tesla clientele.
Check out the pictures and details of some of the products from Redwood Motorsports that we sell. Looking at the pictures of the products below you can see it bleeds quality! :) As always we take the best care of our Tesla owners. To purchase DM us here or visit our website at www.evsmotors.com
Built from the ground up, we have partnered with Öhlins Suspension - the world's foremost leader in damper technology - to pioneer the gold standard for Tesla Model 3 performance coilovers. Found on hyper-cars from Koenigsegg to Pagani, Öhlins dampers represent the pinnacle of modern suspension technology. This suspension blends track-ready damping performance with the compliance and comfort required for street use, and maintains an extremely wide range of damping adjustability.
Designing a shock dedicated for either street use or performance use is relatively simple. However, creating a single damper that is effective in both arenas is significantly more challenging from an engineering perspective. Öhlins' exclusive patented Dual Flow Valve (DFV) technology, along with precision machining, internal seals, and Öhlins buttery smooth 1304 shock oil, yields an ultra-low hysteresis shock which can damp bumps over fractions of a millimeter. For the end-user, the result is a suspension that provides maximum grip in the corners, yet a firm-but-supple ride quality on the street. Those who have driven this setup have commented that the Redwood Motorsports Ohlins kit is surprisingly more comfortable than stock, yet one of the highest grip/performing coilovers they've driven. Best of both worlds!
A full year in development and testing with top motorsports manufacturers has paid off with what we believe is the Gold Standard that other shocks will be measured against. Not only the highest performing suspension available for the Tesla Model 3, but with the most supple ride quality - hands down.
Features:
  • Öhlins DFV Dampers - Custom Tuned by Redwood Motorsports
  • Swift Springs™ - Produced Exclusively for Redwood Motorsports
  • Aurora Bearings™ - Teflon-Lined High-Load Motorsports Bearings (built to last on track and street)
  • Redwood Motorsports Gold Anodized 6061 Aluminum Hardware
  • Redwood Motorsports Nickel-Plated High-Load Front Steel Forks
  • 32 Clicks Damping Adjustment Front and Rear (compression + rebound)
  • Maximum Height Adjustability
  • Ultra-Light Shock Assemblies (shed significant unsprung weight with mil-spec hard-anodized aluminum shock bodies)
  • Öhlins Patented Dual Flow Valve (DFV) Technology
  • Öhlins Temperature Correction Valve
  • Öhlins 1304 Race Oil (Buttery Smooth)
  • World Class Redwood Motorsports Engineering and Damper Tuning
  • Limited Lifetime Warranty
  • MADE IN THE USA! (In Fremont, California)
    (*Aside from Ohlins damper bodies, and Swift Springs)
Technical Details:
The precise control of the Öhlins DFV dampers are both due to the patented Dual Flow Valve pistons, as well as the high attention to detail and component tolerances, typically found on much higher-end shocks. The end result is a damper that has the ability to optimally track the movement of the road surface, increasing tire contact patch and therefore total available grip. Öhlins patented Dual Flow Valve piston contains center and side exit oil flow paths, which allows for separate control of low-speed, high-speed, and ultra-high-speed damping. The DFV has the unique ability to remain firm when it needs to (for body control movement), reduce damping force (for bump control), and significantly bleed-off damping force under high linear accelerations (to absorb abrupt and sharp impacts) instead of transferring them to the chassis. This makes the Ohlins DFV unsurpassed on both the track and street, as berms, mid-corner bumps, and other surface irregularities can be soaked up on track, as opposed to upsetting the chassis.
The same ultra-high-speed damping force is helpful on the street, as a firm-but-supple ride can be maintained for optimal body-control handling, while potholes and large impacts are readily absorbed during day to day driving.
An additional feature of the DFV is its internal temperature correction needle-valve, which meters the flow of shock oil to compensate for changing oil viscosity, based on shock temperature. This needle valve closes for cold temperatures where the shock oil is thicker, and opens to compensate for thinner oil viscosity when the shock becomes hot - resulting in absolutely consistent performance in all circumstances despite the internal temperature of the damper!
*Base Kit Utilizes OEM Tophats*
To learn more about the benefits of Öhlins Road & Track DFV Dampers please visit The Features Of DFV Technology | Öhlins
Redwood Motorsports Spherical Bearing Rear Control Arms Camber/Toe Adjustment - Model 3 / Y​
Redwood Motorsports is proud to present our exclusive Adjustable Rear Camber and Toe Arms - featuring Aurora Bearings™ motorsports grade Teflon lined bearings. These adjustable control arms replace the non-adjustable factory arms, allowing you to dial in custom camber and toe settings to maximize your Model 3's rear alignment and cornering abilities.
Whether you would like to return your lowered Model 3 back to factory alignment specifications for better tire wear, or increase your car's handling ability with increased camber and toe adjustments these arms are for you. Made from one-piece lathed and milled 6061 billet aluminum end mounts, anodized in Redwood Motorsports Gold, our feather-light and high strength arms are designed for long service life and ease of adjustment. The hardened and nickel-plated steel turnbuckles allow an extremely wide range of adjustment and are impervious to moisture, salt, road grime, etc. and were designed to last the long haul! Using the highest-quality and highest-load rating Teflon-Lined Aurora brand bearings, they can be easily serviced if ever needed, but maintain the longest service interval possible for a spherical bearing.
Features:
  • Redwood Motorsports Aerospace Grade Lathed then Milled 6061 Billet Aluminum Bodies
  • Redwood Motorsports Hardened and Nickel-Plated Custom Turnbuckles and Adjustment Hardware
  • Aurora Bearings™ - Teflon Lined Durable Motorsports-Grade Bearings (built to last on track and street)
  • Maximum Alignment Adjustability for Rear Toe and Camber
  • Ultra-Light Aluminum Assemblies
  • MADE IN THE USA!
Redwood Motorsports Front Control Arms Camber/Caster Adjustable - Model 3​
Redwood Motorsports Sway Bars - Front and Rear Set - Model 3​
Features:
Technical Details:
Features:
  • MADE IN THE USA!
Is there even the remotest possibility that after marker suspension could cause Tesla Warranty issues if where the problem is not strictly suspension related.
The Gold Standard would be to have Tesla approve the change and confirm no impact to the 4 year Limited Warranty.
Until that day, I will have to stick to the Coccyx Crushers.
PS I fitted Wilber's to my BMW K bike but there was not a £63k vehicle to worry about warranty wise.
