Excessive wear on leather
Discussion in 'Model S: Interior & Exterior' started by mmcmonster, Oct 18, 2014.
  1. mmcmonster
    mmcmonster Member
    Allentown, PA
    Received my Model S 8 months ago. Most of the time no one sits in the rear seats. About once a week on average, the kids will use the back seats and buckel themselves in.
    I just noticed while vacuuming the car earlier today that I've got a spot on the rear seat leather where the leather's worn through.
    I've never had leather wear through on any vehicle I've owned up until now. To have this happen with less than a year's light useage (that car gets driven heavy, but not much activity on the rear seats) bothers me greatly.
    Is this sort of thing under warranty? What should I do? 2014-10-18 10.06.30.jpg
  2. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    Did you ever have a car seat back there? I saw damage to my Explorer which was very similar.
    A burr on the bottom left of the car seat was found to be the blame in that situation.
    Were I you I would show it to the service center and prior to that contact Tesla.
    Good Luck with it.
  3. tom66
    tom66 Member
    United Kingdom
    FWIW, the seats in Model S are made by an external company "Futuris", which manufactures seats for Ford, GM, Toyota and Mercedes... so I would expect decent quality.
  4. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    That damage could have also been caused by a rivet on someone's jeans tearing into the leather. It's been known to happen.
  5. mmcmonster
    mmcmonster Member
    Allentown, PA
    I don't *think* there was a carseat there. Pretty sure it's not an issue with jeans, either.
    I'll email [email protected] and see if they want to take a look at it.
  6. Krugerrand
    Krugerrand Is Cat
    Tesla unfriendly place
    That doesn't look like wear, but rather 'scratching'.
  7. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    Looks to me like something in your back seat at one point caused excessive rubbing at that spot. Is that a possibility? Maybe you had something sitting back there on the seat for a short time?
  8. Greenlight
    Greenlight New Member
    Canada
    check the buckle part, there might be an imperfection on the plastic part
  9. dejavo0
    dejavo0 Member
    san jose
    Looks like something that should be covered by warranty. Doesn't look like a scratch to me, it looks like the surface peeling.
  10. dan-l
    dan-l Member
    Tampa, FL
    Zoom in on the photo... That's definitely damage from a sharp object, you can see some areas where it penetrated and then cut the leather. Since it is directly below the buckle, take a close look at the bottom of buckle on the seatbelt and feel for a burr.
  11. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    That was my thought, when the belt is plugged in, take a look at where the buckle touches the leather. It’s probably rubbing, and might have a rough edge.
  12. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    It might be caused by manufacturing problem, or people trying to buckle up pushing the other metal part rubbing on the seat. It's hard to buckle without looking at the female part.
  13. andrewket
    andrewket Well-Known Member
    Do you frequently put down the 2nd row? It looks like the seat belt latch may have caused the wear.
  14. bint2k
    bint2k Member
    Toronto, ON
    I'd love to hear the outcome of this. I feel it should be warranty
  15. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    Kind of hard to say one way or another when looking at a picture on a forum, isn't it? When I blow the picture up, it DOES look like puncture marks. But maybe from the seat belt buckle, maybe from something else.
    I think the OP and Tesla will need to do the detective work. I don't think there is enough information to form an opinion - at least not for me. It could go one way or the other ...
  16. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    As others might have mentioned, it might be the buckle either hitting that area on the way in, or once "clicked", the edge of buckle rubbing.
    Was there a car seat in that area that was buckled in for a period of time?
  17. artsci
    artsci Sponsor
    Timonium, Maryland
    That's a very strange wear pattern for leather. Leather does not have a backing and it looks like the surface of whatever that is has been scratched off. I've not seen leather that wears in such a way.
    That looks like the kind of wear that vinyl would show. I'm not sure about Tesla but maybe only the seat surfaces are leather and the sides vinyl -- that's the case in many cars.
  18. mmcmonster
    mmcmonster Member
    Allentown, PA
    Update: I emailed the same picture to Tesla and they agreed that it's covered by warranty. They're ordering the part and will let me know when it arrives.
  19. morbot
    morbot Member
    Seattle
    Did you check the buckle to see if there's a rough edge on it, or something sharp? The spot of the wear... it looks like it'd align with a buckle when connected.
