Currently we've got a J1772 PHEV using an EVSE hooked to a NEMA 14-50 outlet. Then we've got my Model 3 using the UMC into a 120V 5-15 outlet and stealing the 40A EVSE when a fuller charge is needed. We're getting ready to replace the PHEV with a Model X, so I'm debating whether it makes sense to leave things as they are or move to an improved setup.
The wiring comes into the garage and runs in conduit along the left side wall, ending in the 14-50 outlet. I'd like to split the line where it enters the garage, replace the 14-50 with a HPWC, install another HPWC on the other wall, and add the comms line between the two. So the two HPWCs would share the 50A line and provide a total of 40A of power at any given time.
It seems to me that this should be a relatively inexpensive change (outside of buying the two HPWC) since I'm not looking to upgrade the wiring to the garage and all needed work would take place in the garage, but I'm by no means an electrician. Those of you with more experience in this area, what are your thoughts?
Side note: yes, I'm aware that it'd be ideal to have a beefier line in the garage, but our panel is pretty full and 40A should continue to meet our needs. This is really just about avoiding the need to play musical plugs periodically.
