Our Model X 100D is fairly new - just 6 weeks or so. Our typical charging practice is to plug in the Wall Connector before we go to bed and unplug in AM when we go out. Car is set to charge to 80%.
Normally, I'll plug in the cable and start the charge, and when I walk away, the car will lock itself. In the AM, when I go to garage, the car will wake up as I approach (fob in pocket) but the port remains dark. When I unlock the car, the port will then show solid green, and I will unplug and away we go.
Last night was a little different: I plugged cable in, but had to manually (3 fob clicks) close all doors and lock the car when I left garage (wife left passenger door open). This morning, when I went to garage, I did NOT have a fob in my pocket (it was safely far away in house). The car appeared to be locked, but the port was showing solid green. Also, the charging progress screen was visible, and it showed 79%. (Normally, after a night where top-off charging to 80% takes place early in the evening, the vampires will have eaten 2% by the morning.)
I left things as they were, and walked the dog. When we came back (20 minutes later) the charging port light was off. We went into the house, and while there, I heard what I would describe in other circumstances as a relay "chattering" - it lasted 2-3 seconds, I'd estimate. I grabbed the fob and went outside. Now the port light was flashing green. I unlocked the car and saw that there was an error notification saying that the center console was unresponsive, and to reboot. I did that, and system came up ok. I unhooked cable without incident, and that's where it now stands.
Any words of wisdom from the group as to what might have been going on? I am especially concerned about the relay chatter - is that a condition others have experienced? Don't know if it came from the car itself or the Wall Connector.
This is long, I know - thanks for hanging in there and reading this far.
