Exposed wires under wheel well
Discussion in 'Model X' started by Yoonoo, Jun 23, 2017.
Tags:
  1. Yoonoo
    Yoonoo Member
    Spain
    Took delivery of my Model X 100D a week ago and just noticed these wires hanging from under the rear passenger-side wheel well. Part of the wires seems to be exposed but fastened while the other part is just loosely hanging. It does seem strange to have exposed wires like this in an area that's constantly in contact, with rocks, dirt and water.
    Can anyone with a Model X confirm whether this is normal?
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Definitely NOT normal, don't have that on any of my wheels
  3. mongo
    mongo Well-Known Member
    Michigan
    Don't have an X to compare to, but typically wires are placed in a plastic loom or at least taped. Also, zip ties are not normally used to restrain wires due to chaffing (the whitish discoloration on wither side). Did you have any aftermarket accessories added? Usually, the only active object in the wheel well area is the speed sensor, and that runs out the back of the hub (on most cars I've worked on).
  4. BeardedBro
    BeardedBro Member
    Sunshine State
    This is definitely not normal, I would have it serviced right away. I tried my best to take photos of what my X looks like
  5. Yoonoo
    Yoonoo Member
    Spain
    Thanks everyone! Looks like I gotta add this to the list of things to be addressed by the service center.
    Haven't had any work done on the car and haven't installed any accessories.
    Thanks for the pictures! Looks clean, like one would expect. Are you running on 20" wheels? I have the 22"'s and I think with the larger wheels you get to see more of what's going on behind the wheel. But still I don't think you should be able to see wires there no matter what size wheel you use.
  6. BeardedBro
    BeardedBro Member
    Sunshine State
    Yep, 20s. Appears there's an inside quarter panel missing. Let us know what your SC says, good luck!
  7. malcolm
    malcolm Active Member
    What does the driver-side wheel well look like?
  8. MasterT
    MasterT Member
    You made me go out and look - I do have the same exposed wires too
  9. BeardedBro
    BeardedBro Member
    Sunshine State
    Sup neighbor! Yeah that doesn't right!
    I'll have a second look at mine later today.
  10. MasterT
    MasterT Member
    Well, now is the dilemma - ask for the wires to be loomed or not.
    I'm almost positive that they should have been loomed during assembly - protection from scuffing, rubbing, and direct hits. There wouldn't be much protection from moisture as water will still get in there. These wires are located in pretty deep and hard to reach area - the possible of direct hit or rubbing is very remote.
    So, if looming will require disassembly of anything - I will probably let it be as is. If Tesla can loom the wires by removing just the tire and brake pads - I think I will request it fixed.
    What do you guys think?
  11. BrettS
    BrettS Member
    Orlando, FL
    I would get confirmation about whether or not they are supposed to be exposed and then make your decision based on that. It seems like at least one other car has exposed wires like that, so it could be that it was designed to be exposed for some reason. If that’s the case then I would just leave them as is. If you’re missing a liner or something then I would certainly expect tesla to install it.
  12. Yoonoo
    Yoonoo Member
    Spain
    Thanks for checking MasterT. Not sure if this is by design or if both our cars suffered from the same oversight at the factory. (My car was built April 2017). Also, it does appear less of your wires are exposed since they were routed behind that black liner (carpet?).
    If that's how they are supposed to be, it should be easy to push mine back behind that same area. Originally I was just going to tuck them behind the black liner without even removing the wheel, but decided not touch them in case there's a missing part or something.
  13. mongo
    Michigan
    Loom comes pre-split, so the process would probably go something like:
    Cut zip ties
    Place loom around wires
    Add some turns of electrical tape for retention
    Zip tie in place
    Although it is strange that there are vehicles without these wires. Anyone in Massachusetts who can say what they are even for, or where they run?
  14. MasterT
    MasterT Member
    I'm pickin up my car from service today and one of the items on my list was these unshielded wires. Here is what they put on the invoice for my concern:
    I'm going to address it again as I think the tech did not understand what wires to look at (not hoses) even though I provided them with a picture.
  15. mongo
    Michigan
    Ha, tell that to my in-laws. Their Town and Country mostly lost its air height adjust when the plastic line wore through. (ok, if it was better restrained it would not have moved enough to wear through...)
  16. MasterT
    MasterT Member
    Wadayaknow - those are actually ... hoses...
    When I asked a mechanic at the SC, he took me to an X with wheels removed and I could touch the "wires" in questions - they are really hoses, not wires....
    • Informative x 3
  17. mongo
    Michigan
    Interesting. I wonder then if what I thought were scuff marks are features to show where the zip ties go.
    Thanks for reporting back!
  18. Yoonoo
    Yoonoo Member
    Spain
    Thanks for the valuable info! Would have never thought those were hoses. I still think they look out of place, but if that's by design then so be it.
