ExtendView Side Mirrors -- outstanding visibility
jfischer
186
246
Houston
Sorry forgot to upload IMAGE of mirror. This is the passenger mirror. Notice the diagonal line on right part of mirror glass.
This is where the "WIDE" view starts. It will distort a bit around the line as you move from regular view to wide view.
Its weird at first, but you get used to it and appreciate the blind spot coverage. ESPECIALLY with the top on!
attachment.php
attachment.php
MCroadster
76
32
Got them FINALLY from BRG as suggested by @MCroadster. They are AWESOME! You need to get used to the slight distortion of the cars as they get closer where mirror has the "LINE". This shows the separation between normal and wide field of views, but its GREAT for blind spot elimination. I HIGHLY recommend anyone with a roadster to pick up a set. Just expect to wait a few months before they actually show up from British Racing Group....
Thanks for the recommendation!
Glad to hear it worked out.
I was also quite surprised how long it took to arrive, but it has been totally worth it! It fits really snug in the housing, almost like it was from the factory.
Hands down the most useful upgrade I have found so far.
jfischer
186
246
Houston
Outstanding! They REALLY is required. Once you get used to them, you'll wonder how you ever did without them.
Great product. Just be careful putting them on and applying heavy force to the adhesive.
Reactions: RobsJester
da2ny
2010 Roadster Sport Twilight Blue #913
Jul 14, 2018
82
62
Beverly Hills, CA
You were supposed to read the enclosed directions carefully, which they probably did not enclose (Same thing happened to me). However, they were "nice" enough to sell me a replacement for one side for only $80 and include an instruction sheet.
im4uttx
354
220
Spicewood, TX
I remember reading here in a previous message to only press on the outside edges, not in the center. So sorry it broke for you.
I'm still debating whether to order the mirrors. Probably will wish I did at some point, but with the discussion of simply pushing the existing mirror view out farther, I'll try that first to see how it does for me...
jfischer
186
246
Houston
Yes they are glass and VERY FRAGILE.
You cut the 2 round adhesive pads into 4 pieces. Take the 4 pieces and apply to the 4 outside edges of the glass.
Then apply pressure ONLY to the corners where the adhesive is. NEVER press the center as the amount of force will break the glass. There should have been instructions with the mirrors on exactly how to install and caution you on only pressing the outside edged and not the center.
They are great mirrors once you get them installed properly!
sethr
CPO Roadster #1089
Mar 24, 2013
255
150
Fairfax, VA
I would suggest using a good quality silicon glue like GE II instead. Much better than pressure adhesives, IMO. I attached convex mirrors with it on my 2001 Prius and after 17 years when I finally parted with it they were still on, firm as ever. You don't need to apply but the slightest pressure, just use painter's tape so the mirrors will stay in place while the silicon cures.
Reactions: Rolf68
ML Auto
719
725
SW Florida
That is a lot easier. Just make sure that you don't apply too much that is squishes out around the edge.
Bunnak
487
262
Orange County, CA, USA
I do remember reading from a much earlier post that it was best to cut the adhesive pads into 4 pieces and to be extremely careful when pressing the mirror on. Also when I get my car hand washed I always tell them to very careful and not press on the mirror.
hmbprius
45
26
Half Moon Bay CA 94019
it wasn't the instructions...it was the shape/size/design of the mirror...there was a huge gap.....i think I am just going to get one of those corner stick ons, They seem to do the job and are a heck of alot cheaper.
hmbprius
45
26
I do want to share a success story re visibility improvements....not wanting to dive into running any electrical wires I got a completely wireless review camera. Completely. There are 2 on the market that I have found, this one seemed more water proof (based on comments) and solar power...rechargable via USB (but that remains to be seen ...the USB port is way in the back and may have to take the plate off to recharge...will see and cross that bridge when it comes to it. Supposed to last for months on single charge)
Camera was designed to fit on top of the license plate..it arrived already stuck to the license plate backing plate...you could take it off of that which is what I did. Note, I had gotten after market Tesla labeled plates for fun so this may fit differently on your plate frame.
I had to drill a couple of holes in the plate frame (it only had 2 at top) the frame was stainless steel but no big issue to drill holes. It was too thick along the sides to fit in the groves with the provided back panel from the camera kit. There may be another solution (eg design/use another back panel ) but this is what I did: I trimmed off the edges of the license plate outside frame and then everything fit fine. Note I don't have my final license plates yet (just the paper ones) so may have to revise when they arrive.
The camera instead of going on top as pictured on the box (as the tesla bumper light is in the way there), I flipped to go on the bottom. While it was stuck very securely with the tape they provided, I am a bit of belt and suspenders kind of girl, so added a thin stainless bracket I made to go from each of the bottom screw holes in the license plate/holder, and bent to provide an edge support to the bottom of the camera 20190622_191924.jpg
The mount stuck securely using a suction cup in the spacious front seat area (ha!) of the roadster. just plug in to the 12v lighter spot . It comes on automatically and then goes off (user defined 30,60 or 90 sec "on" period...I also unplug after backing out so I can use 12v for phone). 20190622_192351.jpg
Good back up image, Not 170 about 140 degrees. But good enough. With helpful back up lines.20190622_192322.jpg
Reactions: hcsharp
jfischer
186
246
Houston
Okay I need some tips, I got mine, and there is like a 2mm gap in the middle when the edges are in contact..... Even with light touch to trip to push in to get it to sit, it broke.
Yes that the convex part. It sticks out in the center from the mirror. Look closely at these. Notice the gap in the top middle.
attachment.php
Just push on the OUTER CORNERS only and it will work perfectly. they are not going to be FLAT! as then they wouldn't be doing their JOB if they were.
Rotarypower
215
138
Cary, NC
Ughh....yeah the glass bulging out of the side mirror housing is definitely a show stopper for me.
Always thought we needed an aftermarket camera visualization solution, 3 cameras, that would go to a video combiner and provide a single camera signal for a head unit input, switched on with reverse and turn signal inputs. Not sure if there is a solution out there, I’ve looked but nothing seems worthy.
