Exterior wall charger questions
Discussion in 'Model S: Battery & Charging' started by TrevTremaine, May 5, 2016.
  1. TrevTremaine
    TrevTremaine Member
    Toronto, Ontario, Canada
    So, I've got a Model S on order and am looking for ideas about outside charging.
    1) Is there a big issue over running the wall charger cord under a garage door?
    b) If so, does anyone have a working solution for a pass-through from inside a garage?
    2) If I go to mount it outside, I gather that I'd need a weather sealed box - is there any good sources? I would want it lockable and sufficient to keep the charger base and cord enclosed when not in use.
    I don't want to damage the garage door. The walls are concrete cinder blocks, carrying some load. I've already got a breaker box set up in the garage for woodworking equipment which I may try to tie the charger into.
    Thanks in advance for any suggestions.
  2. Edmond
    Edmond Permanon
    Seattle
  3. Rocky_H
    Rocky_H Active Member
    Boise, ID
    You are talking about the wall connector, right? That is weather-proof and approved for outdoor installation. You don't need a sealed box for it. Here is the installation manual for it, and it does have this line specifically listed:
    Note: The Wall Connector is approved for
    outdoor use. Protection from rain is
    recommended but not required"
    https://www.teslamotors.com/sites/default/files/blog_attachments/80A_Wall_Connector_Installation_Manual_EN_JP_ES.pdf
  4. TrevTremaine
    TrevTremaine Member
    Thanks! I didn't know that it was approved for outdoors. Frankly, I've not had the time to look over everything yet, so thanks for the info. I'll have to consider putting some kind of shelter around it as it's fairly open exposure.
  5. Edmond
    Edmond Permanon
    Seattle
    It depends on whether you have the HPWC or UMC. Rocky thinks you have the former, I think you have the latter, but we're both just guessing.
  6. TrevTremaine
    TrevTremaine Member
    Thanks for pointing that out. I'm still trying to understand all the lingo, but I think I'm looking at the HPWC running at 48 amps or so.
  7. Rocky_H
    Boise, ID
    My guess was fairly informed, since his question did actually have the word "wall" in it.
    "Is there a big issue over running the wall charger cord under a garage door?"
  8. fluxemag
    fluxemag Member
    Portland, OR
    I run my UMC cord under my garage door from a NEMA 14-50 outdoor box. It works great. I have one of those rubber seal things that runs along the bottom of the garage door so it fits snugly. It would have been like $3k more to have the outlet in the detached garage, because it would require a new sub panel and wiring through the roof or under ground.
  9. jerry33
    Texas
    You don't want to repeatedly squish the cable. I cut a slot in the concrete to avoid this. Works great.
