EZ Pass Mounting- Problem Solved
Discussion in 'Model S' started by drgallo, Apr 16, 2016.
Tags:
  1. drgallo
    drgallo Member
    Westwood, NJ
    I was looking for a good place to mount my EZ Pass on my 2016 Model S. There were multiple threads here about the problems with the metallic windshield on the car. On my car, there is a black painted rectangular area immediately to the right of the rear view mirror mount. I used the smaller EZ Pass issued by the New Jersey EZ Pass Authority. I mounted it with velcro (just in case) as high on the windshield and as close to the mirror mount as possible, so I couldn't see it from the outside of the car. I mounted it vertically with the narrow tapered edge to the right. It works perfectly, and looks OK, too. I am not sure how many Tesla windshields were marketed with this "sweet spot", but this solution worked for me.
    • Informative x 3
  2. andrewket
    andrewket Well-Known Member
    That's what the black spot is designed for :) The RF shielding isn't in that one spot.
  3. drgallo
    drgallo Member
    Westwood, NJ
    I was cautioned in all of my previous vehicles NEVER to mount an EZ Pass behind the painted or dotted portion of the windshield, but then none of those cars had a metallic windshield.
  4. Blue Millenium
    North Jersey
    Doesn't consistently work. After several tickets I Ended up ordering the outside tag and tied it to the front bumper. Jury still out
  5. kort677
    kort677 Banned
    florida.
    I'm curious, why would you get a ticket? if you have an EZPass account and if the car's plate is on file with them they usually match the plate to the car, and if the plate isn't matched they send you a violation that you can clear by giving them your account number. I've never had to pay a violation fee.
    you can mount the external tag inside the nose cone however that sometimes doesn't work on MTA crossings
  6. rog
    rog Member
    Connecticut
    I'm using an external transponder, works like a charm.
  7. L-P-G
    L-P-G Member
    Orlando, FL
    I guess in FL we're lucky, when I first picked up my car I didn't even take my Epass with me, I simply logged into the Epass page and added the temp tag to my profile until my plate xfered over, since that day it's always done toll by plate. I checked my Epass account and verified the transponder wasn't even being detected so now it lives in the glovebox.
  8. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    I have had an external EZ Pass mounted to my Magneplate license plate bracket, and have had no issues. I'm going to be switching to The Law, so was planning on mounting the external EZ Pass behind the nosecone. I don't anticipate taking the Model S across any MTA crossings, but I also had not heard, before this, of any issues at all concerning mounting the external EZ Pass behind the nosecone. Can you elaborate at all on what you know about people having issues with this please, kort677?
  9. kort677
    kort677 Banned
    florida.
    the issue with the external tag mounted behind the nosecone is that at many of the MTA crossings the tag is not read by there and because of the gates at these facilities you cannot just drive through. at the Verrazano Bridge I sat at the booth, backing up traffic until a bridge cop came along, since he couldn't visually see the tag he shook me down for the cash toll, fortunately I had $15 in cash to give him, where it went I'll never know. when I go up to NY I just use the window transponder by holding it in my my hand out the window.
  10. 808?
    808? Member
    Hong Kong
    Can you mount it behind the nosecone?
  11. Andyw2100
    Ithaca, NY
    Thanks. That's interesting. If I start having issues on the Thruway, I guess I'll have to come up with a different solution.
    • Disagree x 1
  12. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I'm in CA. I mounted mine behind the nose cone. But I have not actually been able to prove that it works. I registered my plate with FastPass before having the transponder and I simply get a charge on my card. Supposedly the thing beeps when I go through. But I can't hear it. And it never beeped when I held it out the window when I first got it. My account doesn't indicate how I am identified.
    15 bucks for the VZ Bridge!!!? Yikes. Glad I moved out west. 6 bucks for the Golden Gate (I think) and she's a lot prettier.:rolleyes:
  13. JD Menteer
    JD Menteer New Member
    La ca
    image.jpeg I just went through this frustration with my new model S 85d. I think there's a lot of misguided discussion about coatings on the windshield.
    The problem is the RADAR used for autopilot, not the windshield. The small signal interaction between the transponder and the toll gates is likely overwhelmed by the radar scanner in the car. I doubt that the transponders work in the nose cone, but they definitely don't work anywhere in the windshield reliably in the newest cars.
    The solution, as someone else posted, is to put the transponder in the trunk. The radar only points forward. This totally solves the problem.
    You can fold down the rear seat so you can hear the confirmation tone from the transponder until you trust it, but the device can be anywhere in the trunk.
    I've mounted mindless on the underside of the shelf. The "hook" side of the Velcro sticks to that location nicely. You don't even need tape. It works perfectly.
    • Informative x 5
    • Helpful x 4
  14. David29
    David29 Supporting Member
    DEDHAM, MA
    My EasyPass transponder is mounted in the black space shown in the OP's post and has worked fine for me at all locations so far in MA, NH, and ME. Transponder is several years old, too.
  15. FlatSix911
    FlatSix911 918 Hybrid
    Silicon Valley
    Great solution - I will have to test this with my California FassPass
  16. Blue Millenium
    North Jersey
    I got the ticket(s) because I had not registered the temporary plate with ez pass. I was waiting for the permanent one.
  17. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    My ezpass is the license plate type that is mounted behind the nose cone with 3M automotive mounting tape , double sided. Personally I feel the transponder mounted inside the car looks something BEYOND hideous.
  18. Fanatic1
    Fanatic1 Member
    San Francisco Bay Area, CA
    I recently had to have my windshield replaced ... probably a small pebble caused a small fracture off to the side and there was a 6 inch long crack extending from the edge of the windshield :(
    The new windshield doesn't have the black area anymore to the right of the rear view mirror mount. Holding my FasTrak pass there doesn't seem to work. Opening the pano roof is impractical and didn't work once. So I'm going to try the Velcro mount under the rear window parcel shelf as suggested. It really sticks there well and really well hidden. Hope it works crossing the Dumbarton next time. $15 for a bridge crossing is highway robbery. We in the SF Bay Area complain about the $6 fee for the GG bridge. We don't know how good we have it I guess.
  19. FloridaGary
    FloridaGary Member
    Orlando, FL.
    Exactly what I did and never an issue.
  20. Andyw2100
    Ithaca, NY
    I just want to point out that the $15 kort677 was a "roundtrip" toll. The main crossings into NYC, like the George Washington Bridge, etc., charge double the toll on the way in, and no toll on the way out.
    Edit: I just looked up the toll for the Golden Gate bridge, and apparently it is also collected going in one direction only, so perhaps the point I made was already understood.
