Why should it be any different?
All EVs have a battery management system, and there's no indication that there's been any change to this for the facelift model, it still manages the battery in the same way as has always been the case.
There are very few user behaviour factors that can have even a tiny influence on battery behaviour and lifetime, like all other EV manufacturers, Tesla lock down the BMS behaviour tightly, so they can provide a long battery warranty, no matter what a user tries to do.
Constantly rapid DC charging the battery, with no lower charge rate AC charges, might cause the BMS to struggle to maintain cell group balance after a while, and may cause the BMS to limit the maximum DC charge rate, perhaps. Constantly charging the battery to 100% may have a very slight impact on cycle life and age-related degradation, and is best avoided. Same goes for constantly discharging the battery pack right down to 0% cut-off.
None of these things are very likely to happen in normal use, though, and by default the car comes set to charge to ~90%, unless over-ridden by the user. From my experience of building and running battery packs for several years now, I'd suggest that staying within the 10% to 90% SoC range ensures a good cycle life, 20% to 85% makes a very small improvement. Anything else is down in the noise, and swamped out by age related degradation.
Cycle life rarely, if ever, is the limiting factor for an EV battery pack anyway, so going to extraordinary lengths to get maybe a 10% improvement is pointless, as age-related degradation will be far greater. For example, take an EV with a 50 kWh usable capacity battery pack, that uses 250 Wh per mile, and is driven for the UK average mileage of ~8,000 miles per year. Over a year the battery pack will get cycled through the equivalent of about 40 full cycles. Cycled from 10% to 90% the cells Tesla use are probably good for between 1,000 and 2,000 cycles, so that equates to a cycle life of between 25 and 50 years. Increasing that to maybe 30 year to 60 years by slightly tweaking the way the car is used won't make a jot of difference in the real world, as age-related degradation will cause the pack to fail long before there's a cycle life issue.
