Falcon Door Collided with Front Door
Discussion in 'Model X' started by CmdrThor, May 26, 2016.
Tags:
  1. vandacca
    vandacca ReActive Member
    Hamilton
    Remember that the fwd door changes it arc depending on its surroundings. It's entirely possible that this issue can only happen on a very small subset of these variable arcs.
    • Like x 4
  2. Vitold
    Vitold Active Member
    NM
    If front door is commanded to close or open and FWd is in 'collision zone' delay opening or closing front door, beep once. Once FWd goes past the zone - continue door command. I would guess the delay would be no longer than 1-2 seconds.
    Another way, if there are two motors in FWd, could be to advance rear motor sooner to keep tension on the door frame to keep it from twisting towards the front door.
  3. rdalcanto
    rdalcanto Active Member
    Salt Lake City
    I specifically asked my DS last week if the doors can collide. He said they can get very close, but won't collide unless they are out of alignment. He did say you can pinch a finger by having it in the gap as the two doors close.
  4. loganintx
    loganintx Member
    Austin, TX
    I've been waiting for the finger pinch comment. I'd seen some video of this happening early on. I pinched my knuckle on my index finger the other day while leaving a Mexican restaurant. Giant metal doors. Door handle protruded far from door. Had my finger on the outside edge and when it passed by the other door there wasn't enough gap for my finger to pass. Still hurts 8 days later. I won't do the same in my X
  5. e_joules4all
    e_joules4all Member
    San Jose
    Yes, my fingers narrowly escaped in the last second while remembering coming across this in the manual:
    Speaking of closing front door, it had happened to me once where the driver door was confused. I closed it very gently by pushing it slowing until latched, and was surprised to find the window overlapping the chrome frame on the outside (a la Adam Levines). After a minute of fiddling, opening the door and lower the window got it back to normal again. Since then, I never use the auto close function as I'm pretty convinced the slamming from auto close would either shatter the glass or scratch the frame. I'd prefer auto close to be soft close to have the premium, civilized feel.
    • Informative x 2
  6. trmmcd
    trmmcd Member
    Arlington, MA
    I had this occur once. I forget the specific circumstance, but the doors grazed each other and pulled on a piece of the trim. I think I had the front passenger door ajar and then closed the FW door. No damage. I picked up my car in mid May. The DS warned me about the possibility of the doors hitting. Based on my early read from this forum - I corrected him and said fingers could be pinched but the doors don't collide. Looks like he was right.
  7. 182RG
    182RG Free The Service Manuals From Tyranny
    Virginia
    ...for the search bots
    Marietta Man Escapes Brush With Death In Unexpected Tesla Model X Collision
    May 26, 2016
    A Marietta man narrowly escaped serious injury when the front door and falcon wing door of his 2016 Tesla Model X collided in a shameless display of inadequate engineering and software programming. @CmdrThor related the harrowing story of near wanton destruction and terror to this reporter.
    "I had just parked and plugged in at work and one of my coworkers stopped to check out the car. Her son is in my son's daycare class so I wanted to show off the Falcon Doors and how well it works with our car seat and such. When I was done I pressed the inside switch to close the passenger side Falcon Door and then pulled the inside handle of the front passenger door to show how it closes by itself. And then *WHACK* they collided. The Falcon Door continued closing and the front door stopped a few inches open."
    Resident brand protectionists decried the event as "sensationalism".
    We'll continue to watch this story closely.
    • Funny x 10
  8. Softwizard
    Softwizard Member
    Keller, TX
    Just imagine how Google's search engine translates words like "collide" and "pedant" into other languages! I can see the Rusian headlines now - "Doors Explode When They Make Contact""
  9. Colby Boles
    Colby Boles Member
    San Francisco, CA
    I think the problem is that the driver / passenger doors can also be closed manually. If the FWD is closing and you quickly close the driver's door manually, I really doubt there is time for the FWD to get out of the way and avoid a collision. The only way to be sure it increase the clearance or maybe keep the driver's window rolled down more when open (assuming this is the point of contact).
  10. elecanuck
    elecanuck Member
    Hamilton, ON, Canada
    Sorry to reactivate an old thread but this exact scenario just happened to me, so no software fix out that I'm aware of. The FWD doors seem fairly well aligned when closed and have been working OK (except with the hinge snap that is happening as reported by some others as it opens and closes)
    And it was a definite CLUNK, and then a SCRAPE...lo 20161023_200726[1].jpg 20161023_200803[1].jpg l
    • Informative x 4
  11. CmdrThor
    CmdrThor Active Member
    Marietta, GA
    Sad day :(
    Tesla ended up taking care of me by replacing my paint protective film on the door. Luckily I had no paint damage. Hopefully they will get your door fixed. To this day I avoid closing both doors at the same time.
  12. bushburner
    bushburner Member
    new orleans, la
  13. elecanuck
    elecanuck Member
    June 20, 2016, one of the later builds
  14. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    I thought that they eliminated this chance in a sw update? Maybe it's only when you select Close All? And with V8 perhaps all that changed too.
