Falcon Doors never open full length all the time
modelx007
259
41
boca raton, fl
Anyone else have this issue? Nothing would be blocking the sensors, yet when pushing on the outside handle, and backing away, it stops short sometimes of fully opening. Thoughts?
Colby Boles
307
249
San Francisco, CA
Same here. It's sporadic and hard to figure out why. Most recently, the vehicle was outside with nothing close laterally and tree folage about 5 feet above the highest point of the FWD when fully raised.
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,895
17,891
North Bay, CA
Maybe they're not opening smoothly and they sense resistance from some kind of hang up. They seem to be really sensitive to resistance if you put your hand on the leading plastic edge. The lift gate, on the other hand, doesn't stop for anyone.
commasign
TeslaAdviceBlog.com
Aug 31, 2013
3,202
4,174
Davis, CA
What do you mean backing away? Try side stepping toward the front driver or passenger door before or immediately after pressing the falcon wing door handle.
Dazureus
326
370
Michigan
Does it open to full when you don't have anything above you, including tree branches? There's an upward pointing sensor that can detect overhead obstacles. Maybe the software is playing it safe with all the reported parking garage problems.
vandacca
ReActive Member
Oct 13, 2014
3,371
2,202
Hamilton
Elon said at the Annual Meeting that the door software was plagued with issues, but it will get sorted out in a month's time. They will move from being worse that regular doors to being better than any door in existence. Here's hoping...
Farnigus
30
18
I've noticed the same thing, and I think you (that is, your body / legs) are actually triggering the proximity sensor.
There are sensors on the sides of the car to determine how far away the adjacent car/wall/object is, and the doors will try to avoid hitting any objects it detects.
The sensors are not very robust yet. For example, if you stand next to the car and click the driver's door, it often only opens by 6 inches and not the whole way. The reason is that the car thinks your body next to the falcon-wing is an obstruction, and the driver's door (which is unobstructed) will not open all the way.
I think the same thing happens with the falcon wing door... In the fully open position, the door actually sticks out to the sides by an extra few inches. I don't think there is a sensor that looks "up and to the side". Only "to the side". So if it only senses 12" of clearance because it senses your body, it won't want to open the door all the way.
For what it is worth, this is a problem in low parking garages, where structural beams are often pretty low. The car will think it has plenty of side clearance and open all the way, only to hit a low hanging beam in a parking garage :(
I've come close to hitting it the ceiling in a parking garage a few times
dtan398
32
7
Henderson, NV
In the meantime, does anyone has any problems opening their falcon doors without hitting the low hanging rails where the garage door
rides on? Or should we play it safe and not even try?
dtan398
32
7
Henderson, NV
The "low hanging beam" that's not the rails the garage door rollers rides on, is it?
Colby Boles
307
249
San Francisco, CA
I have yet to see the problem when completely out in the open, but I did have it happen again while in my garage, which has a horizontal drywall ceiling at almost 12 feet from the floor with nothing hanging down. I had opened the door with my remote and then walked over minutes later and hit my head and almost my eye on the bottom edge of the door because I didn't look carefully at how high it was. This is similar to my tree issue. The lowest leaves of that tree were probably 11 feet off the ground. The central sensor between the FWDs in the roof presumably is as accurate as the ones around the perimeter of the car which seem reasonably good. I'm assuming the sensor in the doors aren't playing as much of a role in ultimate FWD opening height? I agree that this might be intentional in the software, but it's pretty conservative if you can get your FWDs fully up in a 12' high room. Also, the problem doesn't happen all of the time which makes it seem to be more of a sensing inconsistency. Perhaps both?
